sunruh
DJI Thor Posted at 2018-1-8 20:18
Just to verify, did you enable any mode when the gimbal didn't work? And it also happens when you are not connecting to the Goggles, right? If so, please try to reset the gimbal settings, then try again, if you are going to tilt the gimbal upward, please also enable the 30 degrees limit on the Gimbal Advance Settings, and try to adjust the gimbal pitch on the app.
If it doesn't help, could you please provide me with a video of this case? I would like to check. BTW, the gimbal only responds the order of the Goggles if you are in Gimbal Track mode.[view_image]
No, I didn't enable anything when it stopped working. I first noticed it only with the goggle head tracking mode (gimbal track only, not flight). Then I turned off the head tracking and only used the remote to control vertical gimbal and it happened again. I'll go to gimble advance setting and also do a calibration again to see if that changes anything.
While I've got your attention, here is something I have wondered: When in head tracking I have 30 deg lateral movement (left to right) on gimble. When operating only from the remote hand set I can only control vertical. Is there a way to control lateral movement from the remote hand set? |
