DataSphinx
Flight distance : 809426 ft
Curaçao
DJI Thor Posted at 2018-1-8 19:41
Hi there, just to verify, do you mean the speed of the gimbal pitch? If so, you can adjust it in most cases, including the Normal, Tripod, Active Track (except for Spotlight), Cinematic you listed above and so on, go to Gimbal Settings and adjust the Gimbal Pitch Speed. But some modes like Fixed-wind, Spotlight Active Track, etc. can also adjust it, but the settings will have no response on the gimbal in these modes. Hope it helps.
As I understood you can adjust and safe the Gimbal pitch for each mode separately ? That the next time you switch between modes that gimbal pitch you adjusted for that mode is applied?
For Example:
Tripod mode: 5
Normal mode: 30
Cinematic: 9
If that is so please instruct me/us how to do so. If not, please take this in consideration |
