Dockater
Flight distance : 139649 ft
Well ladies and gentlemen, and whoever else is out there. I need your help desperately with the following.
Recently I made a fantastic discovery, as seen in the picture below I found this drone on a pile of junk behind the clinic, waiting to be removed as waste material. Whether it was lost, thrown out by accident or had simply crashed, I have no idea. I cannot find a registration or a manufacturers name anywhere, it would appear to have some minor damage and the propellers are missing. Does anyone know where I can get parts to make a repair and advise me if the DJI controller can be used to fly it, and of course which firmware I should install? Interestingly, the propellers seem to have some sort of special gimbal so they can rotate and tilt at the same time, a most interesting innovation. Sadly the gimbal and camera are missing, but the central fitting looks like it might be compatible to that on the Inspire 2. It would be great if DJI would lend me a ZENMUSE X5S to try out. The drone itself seems to be made of a valuable light metal alloy and is clearly one of the more expensive exclusive models in the manufactures range. This is clear when you see the dark almost obsidian like finish. Thank you all in advance for your help.
I am aware that DJI do not like to be seen supporting third party things so if you want to be discrete you can contact me here - dockater@frankfurt-nervenheilanstalt.de |
