Lenses for X5S
4653 21 2018-1-8
VantageAerial 9
Flight distance : 2543268 ft
Has anyone found a good lens option in the 8mm to 14mm range for the X5S? I dont like the zoom 9-18mm, is there a prime lens in this range that works?
2018-1-8
Hey VantageAeria, we apologize that the Olympus M.Zuiko 9-18mm/4.0-5.6 doesn't meet your needs.
But we still recommend to use the lens in our compatible list since they have been fully tested, appreciate your understanding. lens.png
2018-1-9
Skyris
Flight distance : 333799 ft
You might want to look at the laowa 7.5mm zero distortion, never used it but looks good.. not sure how it balances either but there is a video out there.
2018-1-9
Blackwood
Skyris Posted at 2018-1-9 01:22
I heard that you have to trick this lens to work by starting the drone with a DJI certified lens and then hot swapping to the 7.5mm.
2018-1-9
Skyris
Blackwood Posted at 2018-1-9 11:00
wow thats not cool.
2018-1-9
Blackwood
I was watching a interview with Chris Newman with Drone Pro Academy.  He's one of the top drone guys in the country.  By the way, he owns all types of drones from tiny toys to Octocopters, but in the interview he said that the Inspire 2 is his go to work horse.
2018-1-9
VantageAerial 9
That lens looks like a promising lead! Thanks.  My Inspire is also my go to, it flys like a high end sports car.
2018-1-9
lyxlens
China
Do you think this one can meet your needs
https://www.aliexpress.com/item/ ... OV/32835472603.html
2018-1-9
MaxP4
Flight distance : 13833304 ft
DJI Mindy Posted at 2018-1-9 00:08
But we still recommend to use the lens in our compatible list since they have been fully tested, appreciate your understanding.[view_image]
Hi Mindy, i have Olympus M-Zuiko 14-42 compatible with Zenmuse X5. Il also compatible with X5S^
2018-1-10
MaxP4 Posted at 2018-1-10 00:39
Hi Max, it is good to know, hope you have a great time with it.
2018-1-10
Seachronicity
Flight distance : 852792 ft
The Olympus 12mm is superb!
2018-1-10
fanse11feaa2
Flight distance : 464721 ft
Can I use the x5s camera with my inspire 2 without a license
2018-1-10
fansa84fe8a4
Flight distance : 3 ft
fanse11feaa2 Posted at 2018-1-10 06:58
Yes.  Only need the license for the SSD card and higher resolution files for cinema.
2018-1-10
MaxP4
DJI Mindy Posted at 2018-1-10 02:15
It works very well and is not so close to the gimbal like the X5!
2018-1-15
Of course. It's just you cannot shoot CinemaDNG and Apple ProRes.
Please learn more details about these two formats here: https://www.dji.com/service/inspire-2-license-key
2018-1-16
MaxP4 Posted at 2018-1-15 08:10
https://youtu.be/z-VZzAwsps0
Well done, thanks for sharing the video here. Looking forward to great footage from you.
2018-1-16
CreativeSky
Flight distance : 21241217 ft
What is the A and B column indicate? I just purchased the Olympus 45mm and now it seems I need a balancing ring. Looks like there are 2 different rings? I am confused. Please explain.
Many thanks,
Houston
2018-5-14
rent
Flight distance : 1773458 ft
CreativeSky Posted at 2018-5-14 17:37
Many thanks,
You need both the 37-8 and 37-6 rings for the 1.8/45mm lens (if you are not using filter).
2018-5-14
CreativeSky
rent Posted at 2018-5-14 20:13
Thank you Rent.
2018-5-17
Many thanks,
Like rent said, you will need two balancing rings. If you would like to mount the filter, please purchase it according to our chart, then remove the BR-Ф37-6.
Balancing ring can be purchased in our online store: https://store.dji.com/product/ze ... cing-ring?vid=21751
2018-5-18
fans90d0b13e
Brazil
Hello, I wonder if the Panasonic Lumix G 25mm F / 1.7 Asph lens is compatible with the x5s?
Thanks! Filipe da Gama/ Brazil.
2018-6-27
fans90d0b13e Posted at 2018-6-27 14:18
Please check my post in 2# about the compatible list of X5S lens, this lens is not in the list, therefore the performance and the compatibility cannot be assured. Sorry for the inconvenience.
2018-6-28
