driverseat
Flight distance : 1788576 ft
djiuser_ZrAlicq Posted at 2018-1-9 06:26
Hi all, i've a similar issue with my P3se for 4K video. I'm using a SanDisk 64GB Extreme which is specified for 4K video (U3 and V30). I thought it's good enough. But when starting a record (even for 2.7K) the progress timer for the record in the GoApp wont continue, i can't stop the recording an after 30sec i will get an error advice "SD card invalid" and the cam LED turns red. I've tried a lot of things (restart, formatting on PC, formatting inside the cam, different cluster sizes...), but nothing helps.
Any idea ?
Hi Mario,
Maybe is the problem the formatted 64 Gb Sandisk card as Susan and Nigel suggest. The weather is bad here in Holland for the coming days, so I will not able to figure it out.
As soon I can fly my P3se I will let you know what the results are. It is very irritating to have your bird down to reset the whole thing and wait for the next time it oceur.
So I will keep in touch and will let you know.
Regards
Peter |
