djiuser_ah3HxAM
Flight distance : 318970 ft
Czechia
You can see, that the yaw error started after turn around, after fly one small circle. I observed it on my flights 2 times too. I had 2 time the same problem and the sequence of yaw, atti,... everytime started after doing circle in flight. Maybe its coincidence, but it was in both my cases after circle to right, like in yours. I saw in this cases in my flight, that horizont of recorded video in this time was tilted little to side. After it recovered from errors during flight, horizont narroved. Maybe you will see it in your record too if you have one. I saw, that i usualy had gyroscope after drone power on in orange range little under value 20. compass and accelerometer were ok. Then i did imu calibration, gyro after power on is green around 10 and after few seconds it settles around 5 to 7. Since imu calibration, ive never seen this problem. Maybe its the gyroscope problem. |
