damoUK
Flight distance : 693038 ft
With the Mavic, if you're using a controller, the only way to connect your phone/tablet to the controller is with cables. It comes with lightning (iphone), Micro USB and USB-C, so you should be good to go.
You can buy the Mavic without the controller (useful if you lose and need to replace just the aircraft), but it comes with it if you get the fly-more combo, which you mention you're going for - that will give you everything you need including the controller and cables, case, spare props, mains and car chargers and 4-way hub, extra batteries and battery to USB adaptor (so you can use the batteries like a USB power bank) |
