M210 with XT
1694 14 2018-1-9
US Aerial Video
I am trying to fly a waypoint mission with the XT on my M210 while taking timed stills (every 2 seconds). I am unable to get this to work. I usually use Litchi for these missions but Litchi will not recognize the XT on the M210. GS Pro recognizes the camera but I can’t take timed photos with GS Pro. When I try opening DJI GO4 app it will not show the XT preview image and it also issues a warning saying "use the DJI Pilot App when using the XT" As far as I know the DJI Pilot app is only available on the crystal sky and crystal sky is totally worthless unless you are manually flying.  Ideally, I am trying to take pics with both the XT and the X4S but I will settle for just the XT for now. Has anybody had success with the M210 and the XT using waypoint missions? Thanks!
2018-1-9
rkeihn
Flight distance : 621309 ft
You don't want waypoint missions, you need to build flight plans.  Thats all GSPro does is take timed shots-hover, equal distance, timed.  You can set all of this and just fly using it like DJI Go 4.  Or build a flight plan and pan the camera back up to capture where you want to capture.  I have had lots of success using GSPro, the 210 and the XT.  The only way to get both cameras to capture images is to use the Pilot App on the Crystal Sky, currently there is no other option.   What are you trying to capture or accomplish?  I ended up buying Inspire 2 remote to use as Master and set my Cadence with Crystal Sky as slave to control cameras.
This all being said, currently my XT with no longer work with GSPro, last Apple firmware/DJI Firmware totally messed things up.
2018-1-13
US Aerial Video
Thanks for the info. I will give it a try and report my findings.
2018-1-16
Drone Jones
Flight distance : 87149 ft
Hello!
I haven't used GSPro and have had no reason to have timed shots.  But I do work with at M210 with the XT and X4S dual gimbal.
The only way to capture photos/videos of both gimbals at the same time, is to make the cameras so they are controlled individually (so you can move one at a time).  If you have dual control (where they move up together, down together...) it will only capture the photo/video on the X4S.  The only way I've found to capture both is to control them individually (which really sucks).  So, if you want the same shot, you need to do it twice (once per camera)...unless your cameras can stay in one position and don't need any movement.  In that case I would dual control them to the angle you want, then switch to manual controls and just not touch the gimbals.  That way they are at least pointing in the same spot.
Hope that wasn't confusing.
2018-1-17
rkeihn
Drone Jones Posted at 2018-1-17 07:21
Hello!
That is not the case or correct-my dual system captures stills from both and captures video from both.  As it should, your system is not functioning properly.  Single camera=single image and when XT and X4S are synced they should both be capturing at the same time.
2018-1-30
Olivier Vietti-Teppa
Flight distance : 10169173 ft
Switzerland
rkeihn Posted at 2018-1-30 11:33
with pilot or dji go?
2018-1-30
Zuidwestdrones
Flight distance : 276604 ft
Belgium
You can read my post from 24th of january in this post: https://forum.dji.com/forum.php?mod=viewthread&tid=115035
2018-1-30
Switzerland
I read and do the tests, it does not work, in synchronization mode, only the camera x4s takes a picture, and in individual mode, the active camera takes the picture!
2018-2-3
Zuidwestdrones
Belgium
Cameras on right position? Checking bij de cards?
2018-2-4
fans621af22f
Flight distance : 396365 ft
I had both XT and X4S slaved together and they simultaneously took video or photos.  Used Pilot. M210RTK.
2018-2-5
Switzerland
fans621af22f Posted at 2018-2-5 10:46
I think it worked before, but it's sure it does not work and it's confirmed by DJI, and the X4S is in position I and the XT in II
2018-2-5
Drone Jones
Very interesting.  Yes, it should work that way.  But, you are the only person I've heard where it actually works the way it should.  I don't have the RTK version, but I can't imagine that's the issue.
2018-2-6
jonlorry
Flight distance : 2390722 ft
Hello!
I have exactly the same problem!!
2018-2-7
rkeihn
With DJI Pilot, you can't use DJI GO with the 210.  DJI GO4 you can but with only one camera.
2018-2-11
CPendzi
Has anyone figured out how to fly automated missions with the M210 and XT camera? From what I've tried, GSP doesn't trigger the XT camera to take an image and DJI Pilot does not have planned mission flights.
2018-6-1
