New Battery Concern
12Next >
7392 50 2018-1-9
Fenit2000
Flight distance : 100279 ft
Hi All. New Spark owner here (no not another flyaway story...)
I have had my Spark since Christmas but have not yet flown her more than a few feet in the backyard. Still reading up and educating myself etc. first....
Anyway, I ordered a second battery. This new battery is very tight when attaching to the AC, to the point that you really need to push hard for it to latch. My initial thought was that it was faulty, because the battery that came with the AC fits easily and clicks in place with just a little pressure. When the new battery is connected it feels good and solid, but I am some what concerned that the added pressure may cause it to pop off at some point. Looking closely at the two latches on either side of the battery you can see there is a definate difference in size between the original battery and the one I just ordered. Remember these are new batteries and the one that came with the AC is only a few weeks old, so it shouldn't be down to wear and tear. I  have read of a similar issues elsewhere, but think that was down to an older battery or after a crash. Has anyone else noticed the variation in required pressure to properly latch their individual batteries?
New Battery
New Battery
Original AC Battery
Original AC Battery
2018-1-9
Fenit2000
To be clear, the tighter of the two batteries has the longer latching tabs
2018-1-9
Firehawk989
Flight distance : 198904 ft
Interesting, I wonder if they changed the design of the tabs to help prevent battery pop-outs?
2018-1-9
DJI Elektra
Fenit, do not feel worry about it. If the new battery is solid connected with your spark, it won't pop out. We would not recommend users continue to use spark when it crashes before.
2018-1-9
Oracle Miata
Flight distance : 3759829 ft
Hmmmm,  I don’t notice an immediate difference in the pictures.  I also wonder if a hush hush change was rolled out.
2018-1-9
Fenit2000
Oracle Miata Posted at 2018-1-9 19:27
Take a closer look at the two black triangular shaped locking tabs. One extends further out then the other and there is a significant difference in pressure required to push in and latch the two batteries.
2018-1-10
Oracle Miata
Now I can’t unsee it.
2018-1-10
Shade220
Same issue with my new battery that pops out, which was probably old stock.  The battery that pops out has the shorter tabs.
2018-1-10
BlueBox
Flight distance : 49029 ft
Interesting!
I have 4 batteries, one that came with the spark and 3 I bought more recently; just checked and I have 3 with the larger latches and one with the smaller.
Will power up in a bit and check it the smaller latch one is my original.
2018-1-10
Malakai_UK
Flight distance : 536115 ft
DJI Elektra Posted at 2018-1-9 19:03
https://www.youtube.com/watch?v=cZh0x_5J5XQ
So what do we do if our battery has the small tab and becomes loose over time? Is there a replacement program going to be put in place as this is clearly a defect due to the number of people having the battery pop out during flight.
2018-1-10
BlueBox
just checked my batteries and the one with the smaller latches is the 1st spare battery I bought: production date 2017.6.18, battery that came with the spark is large latch production date: 2017.5.17.
None of them seem to exhibit the issue shown in the other thread about unlatching without using the release buttons.
2018-1-10
Shade220
The battery that pops out, small tabs, has a production date: 2017-7
The battery that does not pop out, large tabs, has a production date: 2017-9
Not seeing a day when checking the production date in DJI Go 4
2018-1-10
Szwedu
Flight distance : 378114 ft
Poland
I have 3 batteries ,the one bought with spark have smaller latches . Hmm
2018-1-11
DJT_MVSP
Flight distance : 2018645 ft
Singapore
Wear and tear on the springs? I think the latches are the same length but those spring could have weaken with use and doesn't push the latches up enough compared to newer ones
2018-1-11
Fenit2000
Both my batteries are less than a month old, so I doubt it is a issue with the springs. The tension on the springs also feels the same to me. The battery that came with the Spark happens to have the shorter tabs as others have noted.
2018-1-11
Viking-Pilot
Flight distance : 2379249 ft
Where did you buy the second battery?
2018-1-11
Fenit2000
Adorama. They specialize in camera equipment here in the States and  are a authorized dealer for DJI.
2018-1-11
djiuser_1E2tlrU
Bought my SparkFiles
2018-1-11
BlueBox
Shade220 Posted at 2018-1-10 08:50
I'm using an iphone with latest app, it provides day, month and year.
2018-1-11
BlueBox
Viking-Pilot Posted at 2018-1-11 05:00
All my equipment came direct from DJI so they are all genuine.
2018-1-11
Linny&HerSpark
Flight distance : 20830 ft
Interesting you should bring this up. I just received a new spare battery and have noticed the same thing: it requires a lot more pressure to snap into place than the batteries I received with the Fly More Combo. Both were ordered from Adorama Photo in NYC. The new battery definitely does not appear to be a 3rd party item.
2018-1-11
Grmachine
djiuser_1E2tlrU Posted at 2018-1-11 06:33
Unable to edit my goofed up post.
What I was saying, is that I bought my Spark last week, and both stock bateries have the longer tabs and hold very firm, seems like DJI did a stealth fix.
Recently watched a short video that showed some batteries wont even lock in at all. They seem to click in, but come right out with a little tug.
Glad they fixed it.
2018-1-11
Oracle Miata
I would say it's very likely DJI that did a stealth fix.  Kinda shady IMO.  I have multiple tiny latch batteries and its concerning if DJI felt the need to change the design without issuing a recall.
2018-1-11
Terp1234
Flight distance : 50906 ft
I came across this clamp at Aliexpress. So there seems to be a market for losse batteries...
2018-1-12
PS013
Flight distance : 3579409 ft
See this recent thread https://forum.dji.com/forum.php?mod=viewthread&tid=128504
2018-1-12
TexasAerials
Flight distance : 566952 ft
I checked all three of mine, the latches all extend fully.  two came with the spark combo bought in July 17, the other bought in august 17.
2018-1-12
DJI Elektra
Malakai_UK Posted at 2018-1-10 08:23
If the part becomes loose, please shoot a video for further check. And we would recommend users mount the battery correctly before flight. Please start a case and provide us the case number when your battery goes wrong and cause accident. We will follow the case and find out the problem. Thanks for your attention.
2018-1-16
Malakai_UK
DJI Elektra Posted at 2018-1-16 01:48
Wait, you are saying i need to wait for an accident to occur before you will do anything?
I would rather not do this. If the catch starts failing and you have already released a revised version of the battery with an updated catch, surely you would be liable to replace the poorly designed ones before an accident occurs.
I checked my three batteries, they are all small catch versions and i notice one of them on one side the catch is already worn down. It still clips in but how long it will last I don't know.
2018-1-16
Szwedu
Poland
RE: New Battery Concern
Are you serious?
2018-1-16
El Diablo
2018-1-16
El Diablo
2018-1-16
Chazzw
Flight distance : 665213 ft
I received a new battery this morning and after seeing this I have compared the latch to my old ones.  The new one is noticeably bigger. There has defo been a design change behind closed doors to combat the battery drop out issue which is a good thing!
But lets be real... pre flight check should always include a check that the battery is secure? So if your battery is not latching log a case with support .
2018-1-16
Malakai_UK
Chazzw Posted at 2018-1-16 05:37
Yes this is part of my normal pre-flight, checking the battery is secure etc but for a DJI Admin to say to wait for an accident to occur then open a case is absurd.
The one battery I have that has a worn catch on one side, at the moment it still sits fairly securely, I can see its going to wear out in the future so its not if, its when! What it if fails mid flight?
I have seen cases on here where people have lost aircraft permanently and all they see in the flight record is that everything is ok then sudden loss of communication similar to the battery disconnecting. DJI have then refused to refund or replace because they couldn't get the drone back.
DJI need to take ownership of this and offer up some kind of replacement program. I don't mind if they just replace the catch with the newer version and ship me my original battery back. I don't want to have to wonder every time I fly if my battery is going to pop out because the catch has worn too much.
2018-1-16
Viking-Pilot
BlueBox Posted at 2018-1-11 07:02
Ok just checking, then they (DJI) should respond properly for that
2018-1-17
Malakai_UK
El Diablo Posted at 2018-1-16 05:23
Stop complaining... WHEN the accident occurs, just shoot a video and get your 30% of discount to buy a new Spark! WHAT part of what Elektra is saying is not clear???
ps. We should bring a GoPro together with the Spark when flying to be able to film whatever unexpected issues as when the problem is battery related the Spark obviously runs out of power so no video recording...
You are being sarcastic yes!?
2018-1-17
El Diablo
2018-1-18
Malakai_UK
phew lol
2018-1-18
Vulcan-XH558
Flight distance : 62054 ft
This is not directed to anyone in general.
If the battery falls out due to a design issue, raise a case, if it doesn't...keep flying.  It really is that simple.
Why on earth would DJI announce to the world that there has been a small design change and have every Tom, Richard, or Harry demanding a replacement?
Richard was added as the swear filter did not allow me to write the shortened version of the name
2018-1-18
mallowsthecat
Flight distance : 213054 ft
Philippines
Hello Fenit2000,
dont be worried that the aftermarket battery for the spark have this tight feel, this is a normal fabrication issue, the first batch of batteries manufactured for the DJI spark that comes with the unit was made using a earlier fab process which is normal for manufacturing. As a product mature or gets released for production or be released commercially aftermarket parts will be manufactured for support to the products, the manufacturer have 2 option Subcon or Inhouse.
The 1st DJI spark batteries are produced Inhouse (which means they are made by DJI) that is
why it fits perfectly to the spark.
the aftermarket batteries are produced by Subcon(which means DJI asked a third party company
to manufacture specific products for them in this case the battery) . this is why the aftermarket
spark battery have a tight feeling makes it feel its not made by DJI(in reality it is not but its authentic)
Reason for this is manufacturers focus on new market and instead pay third party manufacturers
to continue existing product manufacturing. this gives them more resource on new product
developments.
2018-1-18
fansa6d9d300
mallowsthecat Posted at 2018-1-18 23:54
Hello Fenit2000,
may i ask if the battery warranty of 6 months is to be extended when a fault to be found with the premature ware of these inferior clips?
2018-1-19
12Next >
