Gimbal wheel not working
4954 9 2018-1-9
bobjonesx
Trying to use the Gimbal Wheel to change the camera pitch. But the camera is not responding. Are there any settings I should check to troubleshoot before sending the controller in for repair?
2018-1-9
bobjonesx
Never mind. Still learning, I discovered the problem.
2018-1-9
DJI Elektra
bobjonesx Posted at 2018-1-9 18:50
Glad you solve the problem. Here is the link of tutorial:
https://www.youtube.com/channel/UC0sMNc2SGnM-wD3ZGYj3MAQ/featured?disable_polymer=1
2018-1-10
bud
aaagh!  what was the problem? I'm having the same issue.
2018-2-10
eYeSkYeYe
Very wild guess #1: Gimbal sensitivity at 0
Very wild guess #2: Wrong wheel used
Very wild guess #3: Wrong direction of turning the gimbal wheel
2018-2-10
bobjonesx
bud Posted at 2018-2-10 07:43
As you know, the stubby post on the right side of the RC, pushing it forward and then again, will drop the gimbal/camera 90 degrees down, and up again 90 degrees to face the horizon. For whatever (??) reason, I expected the wheel to give the same behavior.
Not so, use the wheel to move the gimbal more slowly from horizontal to vertical in order to achieve some angle inbetween 0 degree and 90 degree.
I was not holding the wheel long enough for the gimbal to respond.
(user error  :-<   )
2018-2-10
bobjonesx
As you know, the stub on the right of the RC shifts the gimbal a full 90 degrees from 0 to 90 (horizon to straight down). For whatever reason, I expected the wheel to behave the same way. (To "assume" makes an ass of you and me.)
Instead, the wheel gives you finer control, to achieve an angle between 0 and 90. But it takes a tick or two to respond. Whereas the stub gives an instantaneous response.
User error!!!
2018-2-10
bobjonesx
Sorry for the double post.
I am SO UNUSED to a forum/bulletin board which gives to response to a "post reply" request. Every other BBS refreshes the page for you and shows your post.
Mehhhh!
2018-2-10
djiuser_Ggii486IDxa9
Please help I don't even touch the scroll wheel and the Gimble start scrolling up And I have to hold the scroll will in the opposite direction to stop it i tried  We calibrating it And  even that didn't work
2022-8-1
DJI Thor
Flight distance : 13602 ft
djiuser_Ggii486IDxa9 Posted at 8-1 16:38
Hi, there. Sorry for your inconvenience. May we know the model of your drone and controller? Besides, if it's possible please provide us with a related video for our further checks. Thank you.
2022-8-5
