Tviscomi
Flight distance : 106886 ft
Wachtberger Posted at 2018-1-10 13:24
Why are you insisting to turn my words into something I have never said? What is your problem please? The OP question was if it was true that CrystalSky and Spark could not be used with OTG and latest FIRMWARE. My response was that they can use OTG with the latest Firmware, but not with the current GO 4 version. And this means logically, that CrystalSky owners like me are in no better situation right now than any other Android user!!! Is that so hard to understand? The truth is that those using other Android devices are actually in a better situation because they simply need to downgrade their GO 4 to version 4.1.15 and can enjoy all functions plus OTG without limitations. On CrystalSky this is not easily possible this way. Thus if your motivation is to blame DJI for something, please do it on a different topic, this one rather fires back...Just what I can swear is, that my answer to OP is correct because I have tested it with latest firmware on all devices involved. OTG is working perfectly, but not with GO 4 versions 4.1.18 or .22. And on that we have hundreds of threads meanwhile, nothing valuable to add though.
I assume you meant to quote this post, "So DJI is recommending not using the most current version of the DJI Go 4 App for use with the CrystalSky?"
Which seemed to have ended in a question mark. Either way the CS does not work using OTG with the Spark. Irregardless of whether or not its a hardware or software issue. |
