Video Recording and Photo Shutter buttons not working
8511 14 2018-1-30
Outlier22
Flight distance : 328474 ft
Good day all,
I've flown my Spark a number of times now but on two occasions I had an issue with the video record button and photo shutter button.
In both cases, I set up the Spark where I wanted to start my shot and tried to hit the record button on the phone but nothing happened.  I tried several times thinking the phone maybe didn't register the touch but no luck.  Then I though that maybe that button doesn't work when connected through the controller so I tried to use the record and the shutter button on the controller but these didn't work either.
I do have an SD card in the AC and I have already recorded with it using both the phone only (iphone 8 plus) and the controller buttons but this time they didn't work.  something I am doing wrong?
On both of these occasions, I was flying in cold weather.  (hey it's winter, what are you going to do?)  I believe it was below the min 32f temp recommended by DJI but I'm pretty sure i've flown in these temps at other times and didn't experience this issue.  Has anyone else experienced this?
2018-1-30
PS013
Flight distance : 3579409 ft
Were you in gesture mode at that time ?
2018-1-30
Outlier22
No, i was flying with controller both times in regular flight mode.
2018-1-30
PS013
Also,
Outlier22 Posted at 2018-1-30 13:05
You can fly with controller, and be in gesture mode, like just after a palm launch
And, as far as I remember, this can be a problem
https://forum.dji.com/thread-100502-1-1.html
Also, did you try to use the record button the remote, instead than tapping the phone ?
( it was cold, may be your touch screen did not work properly )
edit: forget last paragraph
2018-1-30
LouisP
Flight distance : 41952 ft
I had trouble understanding this at first....   If the camera is in video mode and you press the still picture shutter button the camera switches to still mode but does not take a picture until you press the shutter button again.   Likewise, if you are in still picture mode and you press the video record button the camera switches to video mode but does not go into record until you press the record button a second time.  If you are recording video pressing the still picture shutter button does nothing.  Also note that the red lights on the front of the drone are OFF when recording video and on when not recording.  Those things were enough to confuse me so that I could not get the thing to do anything at all.  First i assume the red lights were like tally lights on a camera and when they were on it was recording. So I pushed the record button to stop it (but that started it) and I couldn't get it to take pictures.. frustrating learning curve on the spark sometimes.
2018-1-30
Outlier22
Thanks for the replies.  In my case i pressed the record button on the phone a half dozen times at least and nothing would happen.  Then I tried pressing the video record button on the controller also at least a half dozen times.  Then I tried the photo button a number of times but the Spark would not record or take a picture.
....actually - some additional info.  The second time this happened I was already flying for 5 min or so and was able to shoot video earlier in the flight.  But after some time, the video shutter button once again stopped working.   (both on the phone touch screen and controller.)  This was during the coldest flight in 15-20 mph winds I believe.
The more I think about it, i'm starting to convince myself  that this is cold weather related.  But if anyone else has experienced this let me know ;)
2018-1-30
DJI Elektra
Outlier22 Posted at 2018-1-30 13:43
Sir, any error message from your app? Please try to build the connection indoor and check if the button works. Please tell me the version of your app, the firmware of your drone. Thanks for your support.
2018-1-30
FatherXmas
Flight distance : 4058619 ft
Are connected to the remote with an OTG cable? Or by WIFI? The OTG cable acts a little wonky sometimes.
2018-1-30
Outlier22
DJI Elektra, go4pro version is 4.2.4.  iOS version is 11.2.2.  I don’t know the firmware on Spark but I just updated the firmware on two new batteries so it should be the latest.
I didn’t get any error messages on the app.  It just doesn’t respond when pressing the video shutter button.  ...again, it’s not every time.  This has only happened on two occasions.  I’ve been able to take photos and video on most flights w no issues.  And even on the two flights where I experienced this I was able to start the flight and record video.  It was certainly cold on both these flights but I’ve flown more flights in cold weather w no issues.
(Oh and connecting the phone to controller via WiFi.)
2018-1-30
fansc92e2b11
I'm having the same problem. I was told us because I don't have an SD card yet but I was able to take pictures when I first got my DJI before the updates. They were just saved to the app. And also when I go into my camera settings the panorama and other features are not there. Just single shot can anyone help or is this just an Android issue with the new firmware
2018-1-31
fansc92e2b11
I even tried switching to a tablet. S3 Samsung to be precise and same issue happens. And now for some reason the map is on the right hand side
2018-1-31
mikegyde
My DJI Mavic AIR used to take photos and videos using the buttons on the remote.
Now it doesnt and those buttons do nothing, i physically have to use the phone screen to swap modes and take photo / video.
Super annoying.
factory reset and firmware checks (all current) did nothing!
Help
2019-2-10
djiuser_DCOobi0xdp8T
mikegyde Posted at 2-10 20:32
Same!  Any idea what happened?  I lost two inspections and now I have to bypass the controller shutter button by tapping the button on my phone.  What happened?  Firmware update goofed this up?
2019-2-20
Zohaib farooqui
United Arab Emirates
Did any of you guys find the solution? Am facing the same problem sometimes it happen that the video record option being stuck or locked for some reason i dont know why please help
2019-5-29
Drone Çekimlerim
Turkey
I have that same problem.  the video and photo button on the control does not work.  it takes video over the phone but it doesn't take pictures.  no problem, everything works when you connect by phone via wifi.  I think there is a problem with the remote control.  emergency aid
2019-7-16
