Bashy
Flight distance : 2354357 ft
Thing is though, whats to say the 1st installation didnt go ok and the second then failed and you end up with "issues" "that software" the requires 2 times install could be cause of the way that program runs, there could be an issue with the program that is resolved by doing a second installation, of it could be a failsafe on the software creators side so you are less likely to brick your ac, as far as i know DJI do not say we need to do it twice unless specifically told to do a refresh cause of an issue brought on my the 1st go.
I do not believe the bucking bronco is brought about cause of a dodgy device, same goes for any gimbal issue, ya see, if it was cause of the device then it would be doing it already (before the new FW), many have the same device as before, they update the FW and bang, their AC is not working as it was before. But, this could quite well be (as some have said above) due to an issue during the FW update and not the actual update itself.
I have not had any major issues that i am aware of after an update but, i do feel shes not as stable in the hover as she once was, but then that could just be the wind, and then theres the issue i have with distance, but again, i dont know if thats this FW, that FW or the other FW or even been like it since factory (HW issue) |
