New Mavic Pro Firmware Released (11/1/2018)
69461 439 2018-1-11
drn3px69
Flight distance : 212379 ft
Argentina
drn3px69 Posted at 2018-1-12 09:52
Bad news for me. I flew the first 3 batteries after the update to v01.04.0200
Before with the v01.04.0100 I did not have any problem. Never a error.
Now, in the first session I get 2 or 3 times the "Aircraft Disconnect". The only method that I found to reconnect again was landing, turn off all, and turn on again.
Until today I continue flying with the older version of firmware v01.04.0100 and GO 4.1.22. No problem at all, work like a charm. Also using any cable, on the side or bottom USB port. At minus for me, this confirm that my problems that I get a lot of "Aircraft Disconnect" is something related to the firmware v01.04.0200
2018-1-24
MAVIC VALENTIM
Brazil
Como faço pra atualizar? Esse processo é automático?
2018-1-24
djiuser_F8NQJ2d
Flight distance : 222415 ft
I updated my firmware from V01.04.0100 to V01.04.0200 several days ago.  I'm pretty sure I conducted a test flight and didn't note any discrepancies, but probably need to double check that.  In any case, the next day, the MP wouldn't connect to the RC.  After several attempts, I finally re-linked the two.  Bad day to fly, so next day I set up for test flight, and noted erratic hovering and no pause when landing, which suggested bottom vision sensors not working.  During my checks, I discovered that both the forward and bottom vision sensors are not working.  No warnings or alerts.
Yesterday I called DJI.  Tech acknowledged that they have a known problem that was beyond her capabilities, and that she would refer me to a Senior Tech (still waiting for call back).  I asked about downgrading the firmware, she said I couldn't.   By yesterday evening I grew impatient, so I connected to DJIAssistant 2 to attempt downgrade.  After several failed attempts with RC and MP connected, I tried to downgrade them separately.  Success on RC, but no joy on MP (again after several attempts).  Tried again both linked and unlinked.  I'm re-upgrading firmware to V01.04.0200 using DJI Go 4 now on RC with RC and MP connected to be sure they are both sync'd.  I will probably try to downgrade again after that via DJIAssistant 2.
Thoughts?
2018-1-24
Jos A
djiuser_F8NQJ2d Posted at 2018-1-24 09:50
PM for your answer
2018-1-24
Agent Sgt. Shad
Flight distance : 500679 ft
Released at November 1, 2018?!!? Then how are you guys getting the new update?! It's still Jan. the 24th of 2018!
2018-1-24
DJT_MVSP
Flight distance : 2018642 ft
Singapore
Agent Sgt. Shad Posted at 2018-1-24 12:00
The format is DD/M/YYYY  so this firmware was released on 11 January 2018
2018-1-25
drn3px69
Argentina
MAVIC VALENTIM Posted at 2018-1-24 07:55
Sim, é automático. Você pode usar o seu aplicativo DJI GO no iOS ou no Android ou conectar seu Mavic ao seu computador com o DJI Assistant 2: https://www.dji.com/mavic/info#downloads
2018-1-25
Todd Deringer
Nazar78 Posted at 2018-1-11 04:11
No significant update for Mavic Pro unless you use the Goggles? One of 2018 disappointments
Damn I was hoping for more panoramic pics stuff
2018-1-25
1px0ff
Flight distance : 237238 ft
Todd Deringer Posted at 2018-1-25 08:23
I was just hoping for better pano stitching.  seems like the MP always botches the stitching for some reason
2018-1-25
Agent Sgt. Shad
DJT_MVSP Posted at 2018-1-25 00:06
Oh. Thanks.
2018-1-25
Tealk
Flight distance : 427815 ft
Romania
just an update for Goggles? ...
2018-1-26
Mini-G
Flight distance : 145246 ft
Any chance the intelligent modes featured on the Mavic Air will make their way on to the Mavic Pro?
2018-1-26
Mini-G
Hi does anyone know if you do a firmware update, do you need to plug in each battery into the Mavic and redo the update?
2018-1-26
djiuser_NlFfTSA
Flight distance : 327234 ft
Hello everyone. Is it possible to modify the maximum flight height to a value greater than 500m in this firmware?
On the other hand I am having problems with the RTH. Every time I use it, it continually detects obstacles (which obviously do not exist) and brakes abruptly in the air. So continuously. Has anyone had this problem and knows how to fix it?
2018-1-26
djiuser_F8NQJ2d
Follow up on my previous post.  After re-performing the update (twice), I got my vision sensors back...weird.  Everything now seems to be in order.  DJI Assistant 2 still wouldn't let me calibrate my vision sensors, but that's another story...
2018-1-26
djiuser_F8NQJ2d
Thanks for the help
2018-1-26
martijn1975
Flight distance : 5112 ft
Mini-G Posted at 2018-1-26 05:49
I don't think the batteries were affected  in this firmware.  Normally you will see an pop-up in the app when you use a "new" battery . (a new battery in this case is a battery which was not inserted in the MP during the FW upgrade).  I checked all my batteries but no updates.
2018-1-26
martijn1975
djiuser_NlFfTSA Posted at 2018-1-26 06:51
Are these RTH issues new? So after the FW upgrade or did you experience them before the upgrade as well?
2018-1-26
RL_XXI
Flight distance : 315 ft
martijn1975 Posted at 2018-1-26 12:59
Same here.
2018-1-26
drn3px69
Argentina
drn3px69 Posted at 2018-1-24 07:16
After Mavic Pro worked perfectly with the previous firmware 01.04.0100 and Go 4.1.22 on Android, I discover yesterday, that around the last Monday, DJI update the GO app from 4.1.22 to 4.1.22 (maybe new but with same version number?) on Play Store. After this, on the last tests that I made yesterday I get two Aircraft Disconnects... Maybe today I try update, again, to 01.04.0200 to check if problem are solved with this new version of GO app.
2018-1-31
Numero 5
Flight distance : 873182 ft
drn3px69 Posted at 2018-1-31 05:31
Hello, have you tried if the new GO App solved the aircraft disconnection issue in firmware 1.04.0200?
2018-2-1
drn3px69
Argentina
Numero 5 Posted at 2018-2-1 12:47
Hi, until now I could not prove it, but I have everything installed (01.04.0200 and GO 4.2.4) and ready to test it tomorrow. I share my experience after this.
2018-2-1
Thanh HC
Vietnam
Hi,
I tried using 128GB card for my newly bought Mavic Pro Platinum, checking card OK, tested taking one photo on the new card OK then I went flying.
No warning signal, it seemed quite safe and great to fly. But strange, the drone lost signal with RC even it was about less than 100m away and less than 80m high above. I took several photos and footage for testing purpose. I press RTH button, not work! Again RTH and again, I started to become scared as the drone might fall or mis-operate. . . Finally it returned home, hovering quite a long time above my head, then I had to control it manually to go down slowly and it landed safely.
Bringing it back home, the first thing I wanted to do is to check all photos and video. Quite surprise, all photos and video were not readable even with the latest version of Photoshop/ Lightroom and video Player. . . I saw all the files' properties, file size noticeable (6,7,8 MB for photos and  hundreds MB for clips....) I check the other laptops and PC, could not read either.
Considering all factors, it seemed to me that the incompatibility of the 128GB card was the main issue to cause this and even the unstable control, lost signals. . .
I changed to the 32GB card then it works quite well! :-)
2018-2-1
Numero 5
drn3px69 Posted at 2018-2-1 13:57
Ok thank you!
2018-2-2
Mavic & Goggle 0
is OCUSYNC AIR MODULE IS COMPATIBLE WITH DJI GOGGLES 1 WHITE?.
IS THE NEW FIRM WARE sow new menue in goggles 1 white for controle the OCUSYNC AIR MODULE change resolution etc..?
Thanks
2018-2-2
drn3px69
Argentina
Youre welcome!
2018-2-2
drn3px69
Argentina
Finally today I flew 3 batteries without any problem, I´m very happy, looks that the problem (aircraft disconnect) IS SOLVED. Not super distance flights but all around 2000-2200 mts from home, all was be perfect. Actual versions:
GO 4.2.4 / FW 01.04.0200 / SMG S8+ Android 7.0
REMARK: first I backed up the Flight Records and uninstall the GO app. After this also delete the remnant DJI folder from the internal memory, then I reinstall the GO 4.2.4. I update the Mavic and Remote, via Assistant 2, to 01.04.0200
Done, problem looks solved
2018-2-3
Numero 5
drn3px69 Posted at 2018-2-3 15:51
Happy to hear that you solved the problem and thank you for reporting back!
2018-2-4
fans5abca74f
Flight distance : 52 ft
After upgrading my goggles it start to bugg a lot and it was very slow. is this happened to anyone else? pls let me know.
2018-2-4
drn3px69
Argentina
Numero 5 Posted at 2018-2-4 00:22
Yes, me too! You´re welcome!
2018-2-5
Numero 5
I did exactly your procedure but unfortunately I continue to have many random "aircraft disconnected" issues
Now I reverted back to DJI Go App v. 4.1.18 (android) and testing with it... So far no disconnections (imho in my case the problem  is not firmware related)
2018-2-6
Numero 5
Forgot to say that my device is a galaxy s6 (which is in the supported devices list) with Android 7.0
2018-2-6
drn3px69
Argentina
Numero 5 Posted at 2018-2-6 03:05
Ups! bad to hear that! Looks that in all Android 7.0 not work in the same way. You deleted the DJI folder inside the phone after uninstall the app to make a clean installation?
Sorry that I can´t help more on this.
2018-2-6
Numero 5
drn3px69 Posted at 2018-2-6 11:56
Yes deleted dji folder before clean installation.
Thank you for assistance, I just wanted to share my experience, since now only way to not have disconnections with latest firmware is to using go app 4.1.18
2018-2-6
drn3px69
Argentina
Numero 5 Posted at 2018-2-6 12:58
Yes, I can see here in the forum nice combination is 4.1.15 or 4.1.18 and 01.04.0100 when the user have problems of "aircraft disconnect". For me also work the 4.1.22 (first edition) and 01.04.0100 in case that this info will be useful.
2018-2-7
Numero 5
drn3px69 Posted at 2018-2-7 11:16
Ok thank you for the information,
I've just seen that on play store there is an updated version of DJI Go (v. 4.2.6)  I'll try to clean install it hope this version works without disconnecting...
2018-2-8
drn3px69
Argentina
Numero 5 Posted at 2018-2-8 01:16
Yes, today I saw the same. I already updated and I will try it test it on afternoon. Cross your fingers
2018-2-8
AsturLoko
martijn1975 Posted at 2018-1-26 13:09
I do not remember which was the 1st firmware I had when I bought it, but the RTH worked correctly without encountering the obstacles.
From the 2nd or 3rd update began to occur.
2018-2-8
plugowski
Flight distance : 113488 ft
Poland
What is new in 01.04.0300 firmware?
2018-2-9
Anthony Sparky
Flight distance : 50305 ft
Hi All
The current firmware im running is working fine no issue
Currently I'm running
APP 4.2.8 android samsung 6 +
RC 1.04.0200
Aircraft 1.04.0200
I'm concerned about upgrading not hearing a lot of good
Can someone share some more light
2018-4-13
