New Mavic Pro Firmware Released (11/1/2018)
$gambino$
Flight distance : 1563980 ft
Yea dydog thats it the earth is flat....is that what we believe hillbilly? Come on guy dont say stupid things. seriously u sound slow
2018-1-16
$gambino$
Thanks lamplighter55 for that
2018-1-16
Bulldog
Flight distance : 816158 ft
So when will an upgrade come out that doesn't crash several times a flight?
2018-1-16
Aardvark
Flight distance : 384432 ft
Nees Posted at 2018-1-16 01:04
Problem is not your provider. It is your wifi. If you are on 5Ghz, it will update over wifi. If on 2.4Ghz, your connection will drop because AC and AR are on.
That should make no difference at all to the update process, the 2.4GHz wifi from display device to router should not drop out (Routers continually change channels for best reception, as does the Mavic). However some routers (dependant on their firmware build) can be more susceptible to wifi problems, or poorer wifi signal to start with.
My preferred method for upgrading is to use DJI Assistant 2 on a PC with an Ethernet link to router. Then there's no chance of local interference causing problems with the download. Aircraft, RC and Goggles can all be upgraded directly via this method.
2018-1-16
djiuser_ZvXVwQ5
Turkey
Hi guys! I am from istanbul and my english not good enough. I just want to ask you about that is there any distance limit for new firmware ? And which firmware is the best to fly maximum distance limit (7km) when i go more then 1 km RC signal lost. What shall i do ? Can you please teach me ?
2018-1-16
Guido-Italy
Flight distance : 477008 ft
djiuser_ZvXVwQ5 Posted at 2018-1-16 12:08
Remember that if you fly 7km away you haven’t enough battery to return home !
2018-1-16
integer
Flight distance : 113355784 ft
Greece
you have lost the signal after firmware update?
2018-1-16
RobDownUnder
Flight distance : 103609 ft
Aardvark Posted at 2018-1-16 09:02
I agree with this. Works every time for me where as when I tried over wifi had issues every time. I suspect interference between system messing up the internet. My wife notes that if I start the MP up in the lounge, she cannot get onto the internet via wifi.
2018-1-16
djiuser_ZvXVwQ5
Turkey
Guido-Italy Posted at 2018-1-16 12:43
I cant go even 2 km. After 1km its says rc signal lost. Return home. With last firmware can you go more then 2-3km ?
2018-1-16
djiuser_ZvXVwQ5
Turkey
integer Posted at 2018-1-16 13:34
No! I bought my mavic in october. When i open it first time, its ask me about upgrade and i did it. And i never go more then 1 km. Always same error "rc signal lost" yesterday i did downgrade to fix it but still same. What about if i upgrade to last firmware can i go more then 2 km away ?
2018-1-16
PHL
Flight distance : 1044062 ft
djiuser_ZvXVwQ5 Posted at 2018-1-16 15:18
It also depends what's between you and the flying Mavic; in my case, I sometimes gets good range, and sometimes not, as I have a large experimental communications lab close to where I fly.
Not sure if they sometimes run experiments, but at times the signal is very poor.
2018-1-16
makattack
I'll add my own anecdotal experience, and won't suggest others try it, but it worked for me. I was updating via DJI Assistant 2 on a Windows machine with a WiFi connection (2.4GHz) that was fine speed-wise on downloading the controller firmware, but when the Mavic Pro was turned on, the thru-put was atrocious. When it got to about 25% through, I realized my slightly over half charged battery was insufficient, so I powered it down while it was downloading and noticed the throughput increased significantly. When the download status reached 96%, I powered up the Mavic Pro and it finished the download in about 5 minutes, and successfully applied the upgrade.
2018-1-16
RobDownUnder
Completed upgrade today. Plugged Mavic Pro into desk top which is connected to internet via an Ethernet cable. Worked fine first time. I had limited time available to fly so did a quick check through settings, and a short flight to check all controls were working and then return to home and the precision landing was about an inch off initial take off point. Seems all was well. Not tried distance or photography modes - maybe tomorrow if the wind drops.
2018-1-16
Numero 5
Flight distance : 1385702 ft
I've upgraded my MP to latest firmware, using DJI Go App 4.1.22 (android), now randomly I get "aircraft disconnected" while flying. Never had this kind of issue with previous firmwares, anyone else is experiencing this problem?
2018-1-16
Guido-Italy
do you flight with open air? If drone flights over trees, building etc I think it's normal ad DJI says on manual
2018-1-17
Oranges
Flight distance : 458356 ft
Malaysia
Numero 5 Posted at 2018-1-16 23:36
Me and several other members here are having the same issues. Dare not fly too far away now as it may just happen suddenly.
Flew 6 times, 2 times i got aircraft disconnected midway. Only way to fix it is to restart aircraft and RC . Thankfully stick controls still work and could bring the drone home.. Waiting patiently for a solution besides downgrading . Might be Dji  App update, or firmware itself, unsure.
2018-1-17
Numero 5
Oranges Posted at 2018-1-17 00:58
Thank you very much for your reply, is exactly what I'm experiencing.
I'm thinking of rolling back to previous firmware until DJI will fix this problem.
2018-1-17
Numero 5
Furthermore I don't think it's a problem related to Go App because I was using 4.1.22 before upgrading firmware and never faced the problem
2018-1-17
JohnSmith168
Cambodia
Hi Admin,
Last month I already bought a Mavic Pro after reading a review from this page: https://10techy.com/best-drone-cameras/.
Do you think this drone is already using this new firmware or I need to update it? And how to update it?
Cheers,
2018-1-17
Oranges
Malaysia
Numero 5 Posted at 2018-1-17 01:19
Hmm, Okay, i'll give it a couple of days, if there's no response i'll proceed with the downgrade (too much of a hassle with slow internet) .
Hopefully it gets rectified soon.
2018-1-17
Nees
Flight distance : 80991 ft
Belgium
The update process no IF the firmware was already downloaded, the download process YES. Both devices are on same 2.4Ghz, but the dB on the craft/rc is much stronger, so it is yelling over the wifi signal and the wifi devices will not "hear" eachother again till you turn it off.
At home, my wifi stays connected and after a while windows will say no internet anymore... over 2.4Ghz. For some people this is the "I cant upgrade over wifi but works over 4G".
This is the reason.
2018-1-17
Aardvark
Nees Posted at 2018-1-17 03:00
I'm still not buying it, they are using the same frequency bands, but not the same frequencies as they will be using different channels. And the digital wireless formats are different with Mavic using Occusync & display using wifi (802.11 a,c,n ?). With wifi using packet switching then any errors would force a resend of corrupted data packet.
If what you said was true then every wireless 2.4 GHz Band Mavic upgrade would fail because of incompatible technologies.
2018-1-17
Nees
Belgium
Aardvark Posted at 2018-1-17 03:40
Incompatible no...
But if you know a bit about modding for example your router, you can, if you have a compatible chipset, install DD-WRT, a opensource firmware, and you can modify your wifi Tx power but it is documented not to do se, because you can annoy your neighbors with it, to cripple their wifi, because you broadcast to loud.
For example: my wifi router has a following default Tx power on 2.4GHz :
Tx-Power:16 dBm (40 mW) default
This is ONLY 40mW!
Did you know how much mW your remote puts out? Guess not... 100mW in Europe and a whopping 398mW in the US!
So even on Europe, you are broadcasting more then twice as loud on the same band. Channels will help almost nothing.
If I would modify my router,which I can, I could even set Tx Power 31 dBm (1258 mW) , but I won't, because that is illigal and no-one in my building will have wifi anymore!
Another small thing: bluetooth, what frequence do you think that is on? 2.4Ghz! And guess when, you stream from a phone that is next to your microwave and you turn it on, your music over bluetooth might start to stutter!
But hey, believe what you want. When the mavic came out, many people complained about loosing wifi when they used their craft indoors.
2018-1-17
Mavdude
Plasuable!
Given that the drone wifi signal is quite strong compared to your wifi, and also if the channels being used are very close, it would not be hard to drown out the wifi signal.
I have had other devices kill my internet and the output of them is still much less than the drone.
There will be many corrupted packets, hence why it will go so slow, assuming that the bootloader is not turning off the wifi when in programming mode.
Try putting a tin foil hat over the drone!! Or stuff it in a ferrite lined lead box.
If using wifi, make sure your computer is between the wireless router and drone.
2018-1-17
TomHTx
Flight distance : 35059 ft
When I tried to do this latest upgrade I made the huge mistake of having everything close to each other.  The download was taking forever, and kept failing or timing out.  Then my desktop pc, which had nothing to do with the download, showed "no internet".  It occurred to me that there might be interference being generated by the drone or related items.  I left the drone where it was, but moved the iPad and rc to another room, about 30 ft away, and the change was immediate, and dramatic.  Got it completed with no further problems.
2018-1-17
fans59d4c2ab
Flight distance : 214436 ft
Switzerland
What the actual F...K all the people spamming this thread for stupid gpl code.... Please create your OWN thread ! 9 pages and 8 for these useless GPL code just because you want to change the code to fly in non fly zone... PFFFF
2018-1-17
Hotelone4
Flight distance : 47320 ft
Hey DJI, could we FINALLY get the GPL code released as required? Thanks a bunch!
2018-1-17
Marcustuck
Flight distance : 147146 ft
Colombia
The way I get around the drone jamming the wifi is to power it up and put it about 50m away.  The phone in the controller can then pick up the wifi without the drone jamming it, but the drone is close enough that the software updates well.  I have never got the assistant software to work as with the drone connect by a USB cable the computer losses the wifi.  This is one of the reasons why I would like to be able to download the firmware to my phone and then transfer it to the drone later, I guess DJI don't want to do that for software security...
2018-1-17
rolling56
Flight distance : 138310 ft
Alrighty! a thread about new firmware and it is off topic as hell..........bwahahahahaha
2018-1-17
RL_XXI
Flight distance : 456 ft
Hotelone4 Posted at 2018-1-17 14:18
I have been duly authorized to inform you and others that DJI will terminate your account if you continue to disrupt this thread with off topic conversation.
Create a separate thread to discuss your concerns or you will be deleted.
2018-1-17
MAVICDLNM
Flight distance : 10696686 ft
djiuser_ZvXVwQ5 Posted at 2018-1-16 15:20
The flight distance depends on the location take off and flight route.  DJI claimed 7km max distance actually is the most ideal environment which I haven’t found each place thru out every where I travel yet!
2018-1-17
MAVICDLNM
In that case, I would not update mine Platinum as DJI trend to has bad reputation in new firmware release.
2018-1-17
RolandW
I flew my new Platinum for the first time yesterday after updating the aircraft, controller and DJI GO to the latest versions. Only problem was the app crashing a few times. Running it on Huawei Ascend XT2 phone.
2018-1-18
Locoman
Flight distance : 748675 ft
I also flew test flight yesterday, very windy and cold so cut it short, after I did a WiFi update to FW with Mini4, running current iOS and GO4 app. all devices and router sitting right next to each other. NO Problems with up the date and with test flight. I have never had the app crash during a flight. Never had a problem updating FW over WiFi the first time I tried.  I feel bad for those of you that do. Takes the fun out of flying this drone.
2018-1-18
fans5aee5495
Flight distance : 3772247 ft
The goggles can now play .mp4 films with sound via the microsd card. Another great feature of the goggles with the latest firmware.
2018-1-18
yuumee
Flight distance : 1039029 ft
Taiwan
Nazar78 Posted at 2018-1-11 04:11
No significant update for Mavic Pro unless you use the Goggles? One of 2018 disappointments
There are - just they won't tell you about some of them ;)
2018-1-19
fansa95ed05f
Flight distance : 1335732 ft
Norway
Do you know what the improvements are? - besides the mentioned goggles updates.
I've also updated the firmware, only flown one battery. Worked fine, no issues with iPhone 7(latest iOS and GO-app)
Not seen any differences compared to the old .100 firmware though
2018-1-19
Eric SCHEIDECKE
Flight distance : 2906358 ft
Hi all,
Disconnection issues are only with Android, iOS or both?
I have to work with my MP tomorrow and it would nice to know that in order to choose my iPhone 6+ or my Samsung.
Thanks in advance for your help.
Regards.
2018-1-19
CycleParadise
Flight distance : 385338 ft
Eric SCHEIDECKE Posted at 2018-1-19 09:53
Hi all,
Sounds like issues with both platforms.
I say take both phones with you and try both. See which performs better.
2018-1-19
Eric SCHEIDECKE
CycleParadise Posted at 2018-1-19 10:12
Tku, I'll take both, the problem is that it is a long distance job!!!
I will cross my fingers.
PD: In all disconnection issues, the Aircraft is supposed to return home?!?! This is true or it is only theory?
2018-1-19
