Battery problem
1116 5 2018-1-11
Zer0ne
Flight distance : 25650 ft
Hi, just purchased two new batteries. Unfortunately one of them is not charging. LED no1 on it flashes quickly 15 times and it repeat that sequence in about 10 seconds over and over. When I'm trying to turn it on all the LED light up and switch off straight away not indicating battery level. There is a red light on a charging hub. I did try to charge without hub but nothing happens.
Short video to show the issue
https://youtu.be/O7O5sv8jI_I
2018-1-11
Lucas775
Flight distance : 50642090 ft
looks like a bad cell, need to return it for warranty replacement.
2018-1-11
MiniPalourde
Contact DJI. Looks like a faulty unit.
2018-1-11
A CW
Flight distance : 13838848 ft
Internal board fault or bad cell/s - ship it back asap for a brand new replacement
2018-1-11
4WDaus
Flight distance : 1187257 ft
Assuming battery is not too hot, agree look faulty.
2018-1-11
DJI Elektra
Sir, LED 4 flashes which means the temperature is too high and you can try to cool down the battery. If the problem remains, please contact our support and start a case first: http://www.dji.com/support. When did you buy your battery? Please provide the purchase certificate to our support. Thanks for your support.
2018-1-11
