fansfcddf534
Flight distance : 1370194 ft
Over the last 2 weeks the DJI GO 4 app will not display the height/altitude of the aircraft. Starting on the ground when I lift off to 10 feet the height indicator on the app will show 10 feet then it goes to zero. When I go up another 10 feet it displays 10 feet for about 2 seconds then displays zero. At this point I should see 20 feet on the height indicator but it shows zero. All of the other flight telemetry indicators except for the height display correctly while flying. When I review the flight records on the app the height readings are correct. I am running version 4.1.20 of the DJI Go 4 app. I have an Apple iPad mini running the most recent IOS and a Samsung/Android phone. The issue occurred on both devices. Has anyone ever seen this problem or know of an app setting that would cause this?
Thank you.
