DJI-Darryl
Hi Joe, Weight shouldn't be an issue, but size of the c100 may be,
Also you want to use a wide lens on these gimbals, not a telephoto like the 70-200
not only for the type of shooting but for tilt, the longer the lens the more chances you
wont be able to tilt down very far before hitting the lens on the ronin, But you can limit tilt or pan in the app settings if this is what you want.
Here are the Camera Tray Dimensions for the DJI Ronin M
Maximum depth at center of mass on camera base plate: 120mm
Maximum height measured from top of camera base plate: 195mm
Maximum width: 160mm
If the c100 exceeds these demensions you may have a problem gettting perfect balance on the DJI Ronin M.
