linkin your Remote control with Spark
3753 3 2018-1-12
Nahid Ferdous 4
Flight distance : 154108 ft
Bangladesh
Problem Statement :
If you can't linkin your Remote control with Spark then please flow this statement , it's really helpful .
The Solution is : ( From DJI Engineers )
About this issue, may we know if your aircraft and remote controller has the latest firmware version? To try to resolve the issue please follow the steps that we provided below if you have not yet tried it:
- Press the Pause, Fn, and C1 buttons at the same time.
- Once the controller starts beeping, release these buttons.
- With Spark powered on, press and hold the battery power button.
- When you hear Spark beep, release this button. Linking is now complete.
You can watch the tutorial video on how you can do the re-linking process: https:
We hope it helped. However, if the problem persists you can try an alternative resolution if it resolves the problem.
Please do a factory reset of your aircraft thru DJI Assistant 2.
- Run the DJI Assistant 2 on your computer.
- Connect the aircraft to the computer using a USB cable.
- Go to firmware page.
- At the bottom of firmware page, you will see the reset factory setting option.
Once you completed the factory reset please update the firmware again and then calibrate the IMU.
Battery is greater 50%
1. Turn on RC and Connect to Mobile device.
2. Place the AC on a level surface with the arms folded.
3. Turn the AC.
4. Launch DJI Go app.
5. Go to MC settings > Advanced Settings> Sensors> IMU Calibration> Start Calibration
**FOLLOW THE INSTRUCTIONS ON DJI GO APP**
6. Calibrate in 6 different directions one after another (follow the direction on DJI Go app)
NOTE:
*Make sure not to start the motors with the Combinations Sticks Command (CSC)
*IMU Calibration will fail if the aircraft is not positioned according to the instruction on DJI GO app.
*If calibration fails, restart the aircraft and calibrate the IMU again.
Once you completed the IMU please do the re-linking process again.
Hope that everything helps.
2018-1-12
N9IWJ
Flight distance : 28973 ft
Thanks much!
2018-1-20
Nahid Ferdous 4
Bangladesh
you are welcome , if you have any question then please ask . i am here for your errors ... -_-
2018-3-8
G37 Mavic Pro
Flight distance : 49741 ft
Thanks for sharing
2019-7-31
