Bashy
Flight distance : 2354357 ft
It looks like the device should work in theory. CPU aint too bad and it has 3gb ram, so, my suggestion to you would be to back it off some.
Root the device
Install a slime line version of Android 6 (then ignore all device updates)
Install a slimline version of Gapps (googla apps) prob sommat like playstore and gmail
Then install the Dji app and see if it works, if not then sideload an older version
Use in airplane mode as suggested about too, not only does this extend battery, it will also release some of the system resources normally used
Doing the above should get you going with a device of those specs, as its you main go to device, i would suggest trying to limit the amount of apps you install, more apps running in the background will use up valuable system resources . |
