DroneFlying
Flight distance : 10774613 ft
The drone was not very stable, is due to low light?
Yes. VPS is what provides much of the stabilization you normally see when the Mavic is hovering, but if it's too far above the ground, if the lighting is poor, or if there's no "pattern" the downward sensor can use as a reference point the Mavic will drift around a bit as you described. |
