Jenee 2
Flight distance : 7852129 ft
You can access the simulator from the front screen of the DJI GO 4 app, top right corner, tap on the 3 lines. It is under Academy.
You can also access it using the Assistant 2 software on a PC.
You need to have both the RC and Mavic turned on and the RC connected to a usb port on your computer to use it with Assistant 2. You also need to have the RC and Mavic turned on if using it on your phone/tablet with the GO 4 app.
Just be aware that the Mavic is going to get hot because it is just sitting with the fan running.
