Suren
Flight distance : 13425892 ft
South Africa
Okay. so i went flying today and have 2 phones. one is a samsung s8 with Go4 4.1.15 and the other is iphone 8 with Go4 4.1.22. flew first with S8 and after 20 minutes app disconnected from the AC but managed to land it safly with the remote, no errors or warnings. it refused to reconnect to app, had to restart the AC, remote and app for it to work again. put in a fresh battery and used the iphone this time. i was in an open field with no interfernce anywhere. the iphone was in full gps mode with 16 sats but under the section to check imu, compass etc i see a message to calibrate compass so i doo this and the light on mavic is all green and ready to fly but before takeoff i check that section again and it shows compass calibrate. did this a few times moved to new location and still same, tried the S8 and no calibrate compass showing so i took a chance and flew with the iphone all the while keeping an eye on the two compass readings in the app for any errors and there were none. after this battery went flat changed to another and used S8 and checked for any errors and there was none, used Cap Halls tech of doing the 2mm front back yaw thing and then took off and no issues.
anyone knows why the iphone is always asking to calibrate when the samsung does not???
