Spark Controller QR code damaged
12Next >
34712 70 2018-1-14
fansb5d9524a
The QR code on the back of my DJI Spark controller is partially rubbed off and will no longer scan. Is there any way to obtain the QRcode?
Thanks,
Joe
2018-1-14
Samuel Bona
Flight distance : 236102 ft
Can you send us a picture.
2018-1-14
DJI Elektra
DJI Team
Sir, please do not feel worry about this situation of the blurring QR code. If you want to get back the SN of the RC, you can provide us the drone's SN. Thanks for your support.
2018-1-15
fansb5d9524a
Samuel Bona Posted at 2018-1-14 18:43
2018-1-15
Tviscomi
Flight distance : 106886 ft
No worries...even if the QR wasn't "rubbed off" it doesn't scan 99% of the time.
2018-1-15
Samuel Bona
`What you need to do is input the information manually. Turn on the remote to pairing mode, and then pair it to the DJI spark. Then go into your wifi settings and pair with the remote, you will need the password on the back.
2018-1-15
Fenit2000
Flight distance : 100279 ft
The scanning method never worked for me.I thought it was an issue with my iphone until I looked it up here and saw that others had experienced the same issues. Neither the AC or RC scans work (at least for me), just connect manually. Good luck !
2018-1-15
hallmark007
Flight distance : 12400594 ft
Tviscomi Posted at 2018-1-15 05:34
It’s much better since last update.
2018-1-15
SOUNDWAVE439
Flight distance : 115597 ft
You don't need the qr anyways
2018-1-15
fansb5d9524a
DJI Elektra Posted at 2018-1-15 01:17
Hello, I sent the requested serial number to you via Personal Message.
2018-1-17
DJI Elektra
DJI Team
fansb5d9524a Posted at 2018-1-17 19:23
Thanks for your update. I would reply you in the PM.
2018-1-21
Shaun Ewell
Hi i dont have the password for my controller and and log on to it
2018-7-21
Shaun Ewell
2018-7-21
Shaun Ewell
Shaun Ewell Posted at 2018-7-21 09:45
Hi there this is the controller
2018-7-21
Shaun Ewell
Is the controller password the same as the drones password as mine says its the wrong code.
2018-7-21
Shaun Ewell
This is the original drone passwaord
2018-7-21
kolindji
Philippines
Hi I had the same problem with my faded QR Code. I cannot connect my Spark to the remote using the app from my phone without the QR code to scan. I attached the picture of my remote. I really appreciate someone that could help me with this.
2019-4-4
Tallrandal
I too have had the QR code rub off on my controller. How did other resolve this?
2019-4-22
Rizza Corpuz
Philippines
hi sir, i have the same problem and this is the serial no. of my drone SN:0ASDE940B100PH. Attached is the picture of my qr code that was rubbed. Please have it checked sir,thank you. If you were able to check it sir, please email me at rizza.corpuz1992@gmail.com. Thank you.
2019-6-17
Tentoes
Flight distance : 6247444 ft
If you did not change it, the remote pw is 12341234
2019-6-17
fans307fc575
Same issue SN#0ASUE7700101JU
2019-7-4
Даниэл Ядов
Israel
Hello, I have a problem with my remote control of spark model, cannot scam the qr code, can you please help me?
2019-7-21
Rodanjade Todtod
Israel
Pls help me i cant update my dji spark becouse my QR si blurd what will we to update...pls help me
2019-7-27
Rodanjade Todtod
Israel
Pls..help me my QR . Of my DJI SPARK cant update becouse the QR. Is blurd what will we do to update my drone..help me
2019-7-27
Rodanjade Todtod
Israel
My SN#0ASDE6V1B1000D
2019-7-27
djiuser_tj53p8alcFuS
Norway
So you can make a new sticker?
2020-1-22
Anakin Tai
same case with me....what should i do???
2020-1-27
Marcio naka
Flight distance : 46 ft
Brazil
I'm in trouble and I need help.
my dji spark has qr code deleted, don't read it,
how can i generate another new qr code
the serial 0ASDE951B10002
MY EMAIL Ldamidia@gmail.com
thanks
2020-4-1
fanse153fb77
Hi there,
My QR code and WiFi / SSID details blurred.  Can someone from DJI provide me the details I need to connect?
Thanks
Bryan
2020-4-4
fans58ee1e16
Hello,
The wifi password is deleted behind my remote control.
I just changed my smartphone and I can no longer connect the wifi ...
How can I recover this password?
Thank you for your help.
My email: gauthier.paris.99@gmail.com
2020-4-9
djiuser_twCp5vO5gkaI
I lost the foam box and drone wifi password is partially rubbed off. How can i get the full drone wifi? Please help... my email is johnpope_68@yahoo.com
2020-5-2
Cheysserr
Singapore
Hi, I'm having the same problem can help me check SN:0ASUF6B002003B
Thank you so much
2020-5-21
Jean Rodrigues Santos
Brazil
2020-6-3
Brazil
2020-6-3
dji_MODDER
Flight distance : 84797 ft
You don't need the QR code, now follow this steps to change your RC password again!
Reset the spark wifi, (look on youtube how, believe 9 secs).
Now  check if you see the spark wifi.
also switch on RC if you see the spark RC wifi.
boot spark again, wait fully booted and hold battery 3 sec or more untill you heard the beep.
now switch on rc, press/hold  pause, FN and the special button under the foto button untill beep, put spark and RC within 20 cm of each other.
wait untill green light , connection yes now make connection with the spark wifi
Start DJIgo4, go to wifi settings, you see the RC srnr:, change there your password
2020-6-15
DaMightyMidget
Dear Admin,
I too have encountered this problem and would appreciate your help, with the QR Code and password on  my RC controller being rubbed off. My serial number for my Spark Drone is: 0ASDE8A1C1001A . Please let me know if there is anything else I should do as I am eager to be able to fly again. Thank you!
P.S. I have attached a picture for confirmation.
Sincerely,
  Robert
2020-6-19
dji_MODDER
DaMightyMidget Posted at 6-19 20:00
Dear Admin,
did you try what I am saying?Also for getting your wifi code for your Spark(not RC) just connect to dji assistant2 and look under wifi tab
2020-6-24
David2007
Serbia
I hawe the same problem. Can you please help?!
2020-7-7
Central SkyCAM
India
I lost qr code of my dji spark on the foam box... How can I connect my spark with dji go app.
2020-10-30
djiuser_FSzqh83TVBIZ
Need password for my DJI spark please email me @ mellymine4u2c@gmail.com
2021-2-10
12Next >
