RicardoGray
Flight distance : 4356421 ft
You may have to try an do a manual rest of your RC. Look on this forum for instructions or it may be in the manual. The blue light is telling you it is trying to update I believe. I am not 100%, but I think the procedure is to press C1, C2, record button, and iso/shutter button (upper right on RC) all at one time. You might be able to have the .bin file on a usb adapter that is plugged into the RC if you can't connection the app. Until you get the RC on the same version as the aircraft, you will probably have trouble linking the two together. Sorry I am not able to look in the manual at this time, but trying to remember it from memory. There is a procedure though.
Edit:
I just saw this on another thread about a similar issue with the RC. It was from a moderator:
please make sure the RC battery level is more than 50% and refer the below to try: Hold on the C1, C2, record button and toggle the ISO dial, then turn on the RC and connect with APP. A message of firmware update can be found in the status bar, please check and try to update again.
Hope this is helpful. |
