I dropped my Mavic Pro. I broke a piece that holds the camera, I bought it, I changed it and it still says gimbal vibration abnormal. I have searched and I can not find the solution. I already checked everything on internet. Here you can find a demonstration video:
Sorry to hear your crash, for the gimbal vibration, please check if the gimbal plate is mounted properly, try to calibrate the gimbal, and see if it also shakes when you power on the drone on the ground, if yes, it might be damaged by the crash, then please kindly contact our support, send the drone in for repair. Or you can try to go to the nearby recommended repair center for help.
