Moving the little map???
1553 5 2018-1-15
Jimmy Chance
Flight distance : 28766 ft
Good morning guys, I can't figure out how to move the little map to a different corner of the screen, I would like to be able to move it to another corner for some flights. Thanks for the help!
2018-1-15
A CW
Flight distance : 13838848 ft
You can't move the map.
2018-1-15
Jimmy Chance
A CW Posted at 2018-1-15 10:01
Humm, I hve seen some videos where they show the screen and the  map is in a different corner?? Anyway, thanks for the input.
Cheers
2018-1-15
A CW
Jimmy Chance Posted at 2018-1-15 11:45
Cheers
That may be possible on iPads but definitely not iPhones. The map is on the right hand side on iPads and left on iPhones but I've never seen anyone drag the map around the screen. You can move the histogram by tap-hold and drag. Try that with the map and if it doesn't move on your device then you have your answer I guess.
2018-1-15
jreynolds5
Flight distance : 535341 ft
I have read that older versions of the original go app had the map on the right in iOS and the left with Android. I dunno how tru this is
2018-1-15
DJI Thor
Flight distance : 13602 ft
Hi there, like A CW mentioned, it doesn't support moving the map. If the DJI GO 4 app is displaying on a tablet, the map will be on the bottom right corner, and the attitude indicator will be on the left; if it is on the phone, then the map and attitude will be integrated into one and will be on the lower left corner, you can click the upper right icon on the small window to switch the view. Thanks.
2018-1-17
