Genghis9
Jeff Millard Posted at 2018-2-17 04:49
When it happened, I did as was told by the Go 4 App and landed. I took the bird inside and rebooted it, and I haven’t seen the error since. After doing some reading my memory was refreshed and I realized I was in a mode that doesn’t utilize the Ultrasonic System. Then I began to hear that others had experienced the same issue. There were also some messages about the side sensing being disabled, in modes where they weren’t used. I found those messages stopped if you enable the side sensing via “Tripod” mode. There’s been a rev to the controller firmware for pano mode. My guess is there’s also been a bug fix to correct these two messages... or we are both correct in our thought that the sensors got fouled. The reason I am thinking it was a bug, IMHO it shouldn’t be alarming about modes that aren’t enabled and in use in the particular mode you’re flying in.
Jeff
As you lay it out it sounds very plausible and likely the possible reason for the issue.
My one counter point would be that the VPS will be in use, as Labroides pointed out, when within 7m of the ground/surface below the bird, or when it thinks there is something below the bird.
In this case, it has nothing to do with the side sensors, as you correctly stated they are disabled most of the time except in certain modes.
I've certainly had my problems with numerous warnings flashing at you like a tickertape machine, but I have yet to see this error come up.
Cheers |
