Malakai_UK
Flight distance : 536115 ft
You will find you are using too much pressure to pull it off. As Bigga J said, put the gimbal clamp back on and hold the camera body so that it doesnt move. Be really really gentle in gripping it, as you grip the filter you are actually squeezing it against the camera and making it harder to take off. The other method is to use a wide rubber band around the filter, just gently pinch it off so the band is gripping the filter and pull gently. The trouble with some of the third party filters is they use a rubber gasket instead of a foam one, the rubber gasket causes a seal that creates a vaccum inside the filter making it really hard to get off. The foam ones let air back in and will come off easier. This is why the offical DJI filters just clip around the edge of the front of the camera. |
