RicardoGray
Flight distance : 4356421 ft
Genghis9 Posted at 2018-1-16 03:29
Me personally, I'd call it a day for that battery...these puppies are nothing to fool around with if they go bad and you don't want to wait and see that happen in your drone or in your home. If anything were to go bad in either of those cases you'd be left asking the simple question, was it really worth having held on to it. Sorry for your bad luck here with it.
I'm with Genghis9. Knowing it went into the water, it is a real gamble. In the event of a crash you'll be kicking yourself why you saved it. It would be a bit different if it just came up with the error. Then maybe you could try some different charging routines or deep cycles, etc. The price of the batteries have come down a bit at least here in the US. I wouldn't spent much time with it and if you were able to revive it, use it ONLY for bench testing, settings, etc. I myself would not use it to fly with. Your call for sure! |
