Heavy Vibrations during Auto Tune
864 6 2018-1-16
fansfb52d517
Hello, every time I perform Auto Tune Stability on my Ronin-M, it starts vibrating a lot and makes loud noises. I have it balanced best I can. Is this normal? Also, if this is normal, isn't
this harmful for my camera and lens? Video Link Below. Any suggestions would be great, thanks.
Brandon C.
2018-1-16
bonafideone
This is normal during auto tune. Don't worry nothing is breaking!
2018-1-17
fansfb52d517
bonafideone Posted at 2018-1-17 21:49
Hi, thanks for your reply. My main concern is if the vibrating is bad for my lens. It seems to shake it pretty strongly. You do not think this damages a lens/camera?
Brandon C
2018-1-18
DJI Elektra
China
Sir, please tell me the firmware of your drone and the model of your camera. I would help you forward it to our engineers for further check.
2018-1-21
Fabio E
Colombia
Hola. Mi problema consiste en que después de montar y balancear el Ronin M se enciende y el motor del eje principal no para de hacer ruido y moverse. no lo reconoce el app... Ayuda
2018-10-3
djiuser_tITGXxgRLtOu
I'm having the same (sporadic) problem with my recently purchased Ronin M except mine is shaking violently as soon as it powers on. I've found the only temp solution is to do an auto tune stability quickly but that becomes an issue too as my DJI app rarely lets me in fast enough.  The result is that the rig shakes wildly and the battery gets scorching hot and the unit shuts itself down.  Any thoughts?
2019-2-15
fans282f4878
Dont use camera type or it wil kill your motors
2019-3-7
