Found out how to download world wide off line Maps on Crystalsky ! !
9786 30 2018-1-16
Forestjim
Flight distance : 6606519 ft
Well I hope  have, unless it’s back working again
I fly a Mavic & a Spark but I found the fix by choosing Inspire in Go4
I had to reboot the CS multiple times to bring up option for online maps
Reboot CS and don’t do anything but go to GO4
Choose Ispire 2 top right of screen press = the 3 horizontal lines
If you do something out of order you need to reboot as the option goes away.
Follow the attached screen shots.  start at the bottom photo and go up
I downloaded all of Australia, Hawaii & Florida and they are working
I hope this helps
2018-1-16
lannes
Flight distance : 4465 ft
Great pick up Jim, looks like it works
2018-1-17
JMR58
Flight distance : 627966 ft
Belgium
Had it working this way for me also once, but that is enough to download the maps you need, and they stay located in CS memory.
2018-1-17
Forestjim
lannes Posted at 2018-1-17 01:57
It was a fluke but I’ll take it.
2018-1-17
Far_North
Flight distance : 278379 ft
I got it to work once but Ontario maps would only load to 1% then nothing.  Started over a few times more after a re-boot but could only get Chinese cities.
2018-1-17
TheMann58
Flight distance : 18669501 ft
Far_North Posted at 2018-1-17 15:56
Same problem - only Chinese cities listed to download
2018-1-17
TheMann58
2018-1-17
Forestjim
TheMann58 Posted at 2018-1-17 19:21
Yes the Chinese maps came up for the first.
Did you turn of the Chinese maps options ?
Are in in Inprire 2 ?
Keep rebooting hopefully you will get it to work
2018-1-17
TheMann58
Forestjim Posted at 2018-1-17 20:14
Success!  I rebooted a couple more times and then all countries were displayed.
I then successfully downloaded maps for:
All of North and Central America 8.04 GB
United Kingdom All Regions 793.28 MB
Greece 441.13 MB
TIP: When downloading large regions, scroll the screen up or down every 30 secs or so to keep the Crystalsky from auto powering off, which will pause the download.
2018-1-17
TheMann58
Greece 441.13 MB
2018-1-17
Far_North
SUCCESS!  I tried it again before I went to bed and it worked.   Just using the display with no AC or RC connected.
2018-1-18
Forestjim
Far_North Posted at 2018-1-18 05:18
Well done.
That’s how I did it
2018-1-18
Josemilla
Flight distance : 185728 ft
Good job, community. The same can not be said about DJI ...
2018-1-20
Johan97
Flight distance : 37201217 ft
Sweden
Hi Guys,
Downloading oflfinemaps have not been my problem.
The problem for me and maaaaany others on this forum is that once they are downloaded offline, everytime that you startup the app you get into some sort of "China mode" and the map shown will be "no map" at all, and in the map screen there is a chineese sign/word and going into the offline maps section of the app there are only China regions listed.
To get out of this mode there is no clear way (for me) but if you turn on and off the app, and also going into the offline maps section in and out a couple of times, it eventually loads the correct maps.
Extremely enoying and DJI they just do not have a clue as usuall, however they are giving out all sorts of useless advices, even when they know that the offline maps do not work.
2018-1-20
BRIDEL
Johan97 Posted at 2018-1-20 04:08
Hi Guys,
I do not need to repeat the same. SAME issue and still not able to fly my drone. What to do ?
Since I am totally  new on this Do i need the offline maps ? or if i try to fly it, will it show some local map ??
???  Sorry if dumb  question
2018-1-22
BRIDEL
BRIDEL Posted at 2018-1-22 11:23
I think i found the answer to my dumb question. The CS has GPS so any place any where it will be able to connect to the satellites regardless i have downloaded or not offline maps.
The offline maps are for more in detail view ? true ?
2018-1-22
Forestjim
BRIDEL Posted at 2018-1-22 12:51
Yes Mate. I only use offline maps when I’m overseas with out cellular
You can use wifi or wifi your phone to download detailed maps
2018-1-23
Forestjim
You are correct about the gps maps.
Offline maps  I use when I’m overseas or no cellular network.
You can use wifi or wifi your phone up to get the more detailed maps.
2018-1-23
BRIDEL
Forestjim Posted at 2018-1-23 04:19
Thanks, Does it means as follows :
1. If you are overseas , NO WIFI, but able to connect to satellites, the crystalsky will pull up the already downloaded maps -- Correct ?
2. If you are overseas , and NO WIFI, and NOT satellites  ,  then can NOT fly your drone  until you get the correct number of satellites needed . --- Correct ?
Thanks in advance
2018-1-23
Forestjim
BRIDEL Posted at 2018-1-23 17:12
Yes Correct - The Maps are there - You don't have to be overseas to use this feature, Its when you don't have access to Wifi ( INc hotspot cellular data)
2. If you are overseas , and NO WIFI, and NOT satellites, then can NOT fly your drone
Yes can still fly your done if you don't have satellites. You just can't  use DJI Go. Just fly on your sticks in Atti mode. I try not to do this but you can.
Cheers
Have fun.
2018-1-23
BRIDEL
Forestjim Posted at 2018-1-23 17:29
Thanks so much.
I have noticed the Academy videos are not playing in my crystalsky  monitor for some reason .  Is that something people have noticed too ?
I need to do all the correct settings in my MP first before any fly. lot to learn and  lots of  youtube videos to watch..
I want to continue studying and practicing first with my  syma x5c drone first
2018-1-24
uweneumeister
Flight distance : 2172717 ft
Thailand
Thx mate tried this before, didn’t work. Did you do this with your inspire connected?
2018-1-26
Forestjim
uweneumeister Posted at 2018-1-26 10:07
No mate. I don’t have a Inspire. That’s was the only place i could find the option for offline maps after multiple reboots.
NB. You don’t connect any drones whilst you are doing it.
Good luck
2018-1-26
Kleetus
Flight distance : 241339 ft
HI- This looks like a great fix but I have tried this multiple times with no success. I am on CS Firmware version V02.02.00.00.  Is this the version you are using or are you on a previous version?   Thanks, Kleetus
2018-3-16
Kune
Flight distance : 2773465 ft
I also tried several times  without success.
2018-3-16
Forestjim
No.... we will have to wait for update
2018-3-16
Wyke
Flight distance : 33166 ft
Forestjim Posted at 2018-3-16 21:13
And we all know how long those take for the CS.....
2018-3-17
hridge
Flight distance : 17651 ft
Still not working for me......
2018-3-19
wondermutt
Flight distance : 292260 ft
Has anyone tried this recently?  Just picked up a CrystalSky and it looks like this is no longer an option...Thanks.
2019-7-10
baileyshaw123
That's a great guide because i have been looking for this to implement a same type of query in my website. I have implemented maps on many websites because i have been doing web design dubai for about 4 years.
2019-7-23
fans8e6784cd
wondermutt Posted at 2019-7-10 09:41
Not working. Only black screens for mapbox. No downloads either.
2023-3-28
