Labroides
Flight distance : 9991457 ft
Jim Watkins Posted at 2018-1-18 06:57
The Flight was at 12:05 PM. Not looking into the sun. I have flown under that freeway many times and losing GPS never caused this before. And like I said, it happened the day before in an open park with nothing around. Very strange. I could repair it myself. I have replaced the shell before, but I am not sure I want to do it again. It's a project. I wonder how much it would cost to have it repaired.
As I said, the log doesn't point to the cause so I'm only guessing what might have happened.
Obstacle avoidance is something that could cause the Phantom to ascend in flight even if you are trying to descend.
Did you have OA enabled at the time?
You were flying in an uncommon situation, in a dark area under the freeway bridge that blocked GPS.
I suspect that the incident is not random and was related to the environment there at the time.
It might be that your Phantom was trying to avoid an "obstacle" and it might not have been the sun but could have been a bright area on something the sun was shining on ... a white car, a bright piece of concrete or something like that?
The obstacle sensing system has several limitations.
Here are some from the manual:
The performance of your Vision System and Infrared Sensing System are affected by the surface being flown over.
Ultrasonic sensors may not be able to accurately measure distances when operating above sound-absorbing materials and the camera may not function correctly in suboptimal environments.
The aircraft will switch from P-mode to A-mode automatically if neither GPS nor Vision System and Infrared Sensing System are available.
Operate the aircraft with great caution in the following situations:
a) Flying over monochrome surfaces (e.g. pure black, pure white, pure red, pure green).
b) Flying over a highly reflective surfaces.
c) Flying at high speeds of over 31mph (50kph) at 2 meters or over 11mph (18kph) at 1 meter.
d) Flying over water or transparent surfaces.
e) Flying over moving surfaces or objects.
f) Flying in an area where the lighting changes frequently or drastically.
g) Flying over extremely dark (lux < 10) or bright (lux > 100,000) surfaces.
h) Flying over surfaces that can absorb sound waves (e.g. thick carpet).
i) Flying over surfaces without clear patterns or texture.
j) Flying over surfaces with identical repeating patterns or textures (e.g. tiling).
Note particularly F & G.
The .dat file recorded in your Phantom gives more information than the .txt file in the app.
It would probably indicate whether obstacle avoidance was triggered.
You could try looking into that to get more detail.
