A CW
Flight distance : 14177772 ft
Ok - so you've reset the camera, tried manual focus, cleaned the lens and presumably the ND filters, view the same focus issues on the SD card files. If this happened following the recent firmware update perhaps try refreshing it or downgrading it using Assistant 2. If that fails, best to follow DJI Thor's instructions in post number 3 for the pro's at DJI to take a closer look. Worse case you may need to return the drone. |
