Giammi
Flight distance : 847795 ft
Hello everyone, I've just restored to factory settings my Phantom 4 Pro Plus, as I've been suggested to do in order to try to correct an issue on the maps. It worked fine and now the issue is solved. BTW the DJI GO 4 app now give me an alert message when checking the aircraft status. It says "abnormal", probably the developer of the code was a big fan of "Young Frankenstein"! But, jokes apart, if I press on the error, I get a suggestion to calibrate the vision sensors through DJI Assistant 2. Then I downloaded it and tried to perform the calibration, but, when starting it, I can correctly make the app recongnize the drone but no way to go through the calibration process. I just have a white screen on my MAC without any reference to align the drone camera to. This way I have to stop the calibration.
Another weird thing, probably connected, is that DJI assistant 2 is not able to retrieve the installed firmware version on my P4Pro+.
Anyone else experiencing this issue on MAC OS?
(Drone and Controller are up to date with latest firmware)
