Why are flight records splitted ?
ThePhenix33
Flight distance : 1894797 ft
Hello ! Is it normal that my flights are splitted ? In 20minutes I've got 2 or 3 flight records , like on the photo linked. Are my flights times false due to this (366 times) ?
Thanks,
YB.
2018-1-19
A CW
Flight distance : 13660256 ft
Flight records can split if you land, disarm the motors and take off again on the same battery and/or if the signal is lost and regained during flight/app crashes.
2018-1-19
ThePhenix33
Oh ok, I didn't knew it was making a new flight when the signal is lost. Thank you !
2018-1-19
ALABAMA
Flight distance : 10422228 ft
Are you landing sometimes between flights on the same day?
2018-1-19
DJI Thor
Flight distance : 13602 ft
So the signal did lose during that flight, right? If so, it is the reason you got the split records. If the transmission, RC lose signal or the connection between the RC and app fails, the flight record might be interrupted, if the signal regains, the record continues, and it might generate multiple records like your case. So if the signal loss on that flight, it was normal for your case.
2018-1-21
ThePhenix33
Yes, I understood by A CW's answer, thanks !
2018-1-21
