Phantom 4 Series Battery Charging Hub-Buy or Don't Buy?
Genghis9
Flight distance : 961 ft
I have wanted to get the DJI Phantom 4 Series Battery Charging Hub for some time now.  However, in doing my research and reading reviews I have found too many reporting that the device has bricked their batteries when in storage mode.  This would be catastrophic losing 3 batteries in one swoop if that were to occur.
I am looking to hear from whomever out there who has this item and what their experience with it has been and recommendations for whether I should spend the money in getting it.  $90 US is not a small amount of change, although I noticed that Amazon sells the same "DJI" item for a noticeably less amount, but I was wondering if they were selling refurbished units.
Any suggestions, opinions, and thoughts are welcome, please.
https://store.dji.com/product/phantom-4-battery-charging-hub?vid=6381
USD $90
Charge 3 batteries together
2018-1-19
KedDK
Flight distance : 1133038 ft
Denmark
To my best understanding the problems with storage mode has been said to be a problem with the firmware in the charger.
The firmware is supposed to be found in the P4 download section but i see none so i guess there has been no updates, perhaps yet a bad supported device from DJI?
I think that if you do not leave the batteries in the hub for longer times it would be safe to use, remove the batteries when discharge to storage level is done.
If you bite the bait, please let's hear how it turns out.
Edit: the firmware download link in the manual for the charger, http://www.dji.com/product/phantom-4/info#download change to this link https://www.dji.com/phantom-4/info#downloads so the manual also is not up to date ...
2018-1-20
KedDK
Denmark
Also take a note on the specifications in the manual, seem to not support the high capacity batteries.
2018-1-20
Genghis9
KedDK Posted at 2018-1-20 01:44
If I do I will let you know...I'm not surprised that the manual is out of date, par for the course in that department.
2018-1-20
Genghis9
KedDK Posted at 2018-1-20 01:55
[view_image]
That is an interesting note, it does say P4 Series though...mismark, out of date, makes you wonder now doesn't it...it would be nice to have a charging hub.  In this case I'm not so sure, as I'm finding more questions than answers...
2018-1-20
KedDK
Denmark
Genghis9 Posted at 2018-1-20 02:44
I guess it is a part of a outdated manual but if i was in your shoes i'll get a written reply from DJI that it is good for your needs and batteries.
Should something turn out to go wrong, as is DJI can tell you you used batteries out of specs and you hang on the costs ...
2018-1-20
sky wombat
Flight distance : 1454078 ft
for some obscure reason the charging hub was included in my purchase price of the P4P. Don't know why but good to have a win now and again Has been a handy thing to have but I haven't used it in storage mode.
2018-1-20
BigBlueTsunami
Flight distance : 503635 ft
I have one. I’ve used it on ten charging cycles with no problems. After each battery has been used, I switch it to storage and place all three batteries in it at the same time. It sets each battery to storage and an led turns blue. I take them out of the charger and store them until next charge. Working fine so far.
Jeff
Edit” I forgot to say that I purchased this item from an authorized reseller on eBay”
2018-1-20
BigBlueTsunami
Here it is just after completing the days charge...
Jeff
2018-1-20
S.D. Pilot
Flight distance : 10278435 ft
Hey Genghis9, I have one and it's never bricked my batteries or given me any issues at all. Bought mine from the DJI site.
2018-1-20
Genghis9
BigBlueTsunami Posted at 2018-1-20 07:37
Jeff
So you let them work till they are down or up to storage levels and then remove them for physical storage after that, correct?
2018-1-20
Genghis9
S.D. Pilot Posted at 2018-1-20 10:29
OK good to know, and I assume you have used both modes, yes?
2018-1-20
BigBlueTsunami
Genghis9 Posted at 2018-1-20 16:06
Yes that is correct. I fly until I'm close to the preset 30% alarm point. Then I change batteries. When I return home I switch to storage and insert all three batteries. It sets each, one at a time, to the storage value and the LED next to the battery turns blue. I remove all three when it has completed. I recall that it usually only takes about 30 minutes to cycle a storage charge.
Jeff
2018-1-20
eman_vg
Flight distance : 1015440 ft
Buy It!! I have my smart hub, and it works to its capabilities
2018-1-20
S.D. Pilot
Genghis9 Posted at 2018-1-20 16:07
yep and also use the 160w cord with it and not the 100w one. Charges a bit quicker too.
2018-1-20
Dockater
Flight distance : 139649 ft
I can give mine the green light, so far at least. Bought from Amazon if I remember correctly.
2018-1-20
Jenee 2
Flight distance : 7852129 ft
I use one and have never had any problems. I find it very handy to use for putting batteries into storage. It is much easier to use the hub then to have to run the batteries down to storage level in the Phantom.
I would advise to buy one either direct from DJI or an authorised DJI reseller.
2018-1-20
Genghis9
BigBlueTsunami Posted at 2018-1-20 16:56
Jeff
OK sounds like good advice thanks
2018-1-21
Genghis9
eman_vg Posted at 2018-1-20 17:04
Are you using the newer high capacity batts or the orginial P4 batts?
2018-1-21
Genghis9
Dockater Posted at 2018-1-20 18:48
Can you tell me or PM who the seller was and the price and when you bought it?
please
2018-1-21
Genghis9
Jenee 2 Posted at 2018-1-20 22:01
Thanks, I assume you are using the newer High Capacity batts?
2018-1-21
Dockater
Genghis9 Posted at 2018-1-21 02:37
Hi Genghis9, my batteries are:
DJI PHANTOM 4 5870 HIGH CAPACITY
Currently the suppliers of the charging station in Germany are:
Of course DJI online store Germany is Euro 99
Saturn (large electronic chain store) Euro 62 (this may be a one time special offer)
Amazon prime Euro 79.99 (supplier my Hobby24)
televerkauf Euro 59 + 7.90 delivery
Then there is Tec & Hobby for Euro 85 and others increasing in price to Euro 120
Sorry I can't find the supplier or price of my original purchace easily, it was not Amazon though, I have checked.
Hope that helps - Doc
2018-1-21
eman_vg
Original, I don't really trust those off market batteries.
2018-1-21
Genghis9
Dockater Posted at 2018-1-21 04:15
Yes thanks!
2018-1-21
Genghis9
eman_vg Posted at 2018-1-21 09:29
OK Thank you for your help and information
2018-1-21
Jenee 2
Genghis9 Posted at 2018-1-21 02:40
I wasn't aware there was more than one battery for the P4Pro. Mine are 4S, 5870mah.
2018-1-21
Genghis9
Jenee 2 Posted at 2018-1-21 20:08
Well not exactly, but you can use the older original batts from the P4S while they aren't as powerful they can still be used...which is why I thought I'd ask
2018-1-21
sky wombat
So Genghis9 have you taken the leap yet and purchased the charging hub?
Must confess I had forgotten about the Storage Mode so guess I should read the manual. It's only five pages (incl contents page) but if you read it slowly it could take ca. a minute. It's also good value for money as you get about 42 other languages in the same booklet.
2018-1-22
