effen
DJI Thor Posted at 2018-1-21 22:42
Hi, which model is your Ronin (Ronin, Ronin-M or Ronin MX)? Please check if the battery connection and see if it is normal. If you are not able to connect the PC, just to verify, did it work before? Will it work with your mobile device, please try to connect the Assistant on the mobile device. If it is possible, please provide me with a video of the Ronin and a screenshot of its serial number, we will help to check. Thank you.
i have a ronin, it used to work perfectly, it stopped working all of a sudden sometime between 2 film shoots, it seems to be working fine now. but it makes me uneasy that this problem could reoccur.
my sn is 0330036904 both battery and connection are fine.
i believe the problem is behind the panel where the bind button is located(that is where i was flicking the device).
When i was having problems the light by the bind button was not turning on i feel and fear something is not receiving power |
