KedDK
Flight distance : 1133038 ft
Denmark
From their Faq i wouldn't count on it:
What drone piloting applications are compatible with BT-300?
DJI GO app 3.0.1
Can I use DJI GO 4 with BT-300?
The DJI GO 4 (version 1.0.0) application will be available for download on the Moverio Apps Market at the end of January 2017; however, the current version must be run in parallel with another app called Rotation Locker, which can also be downloaded on the Moverio Apps Market. Please first open Rotation Locker and select Landscape Mode. Next, open DJI GO 4.
It somehow sounds outdated, so if i were you i'll try to contact Epson and ask or make sure you can return it to seller if you just want to try. |
