P4P 01.05.0300 firmware update
1251 11 2018-1-20
Phil Mountain
Flight distance : 732326 ft
Finally updated P4P firmware to 01.05.0300 running DJI GO 4 version 4.1.22 on an Android 6.0 tablet. Only bug to report is Active Track doesn't appear to work any more. Anyone else have this problem? Is it the Firmware or Android app?
2018-1-20
Nebicaneser
Flight distance : 3440476 ft
did you ty reinstall the app ?
2018-1-20
Phil Mountain
Nebicaneser Posted at 2018-1-20 11:54
Not yet but I'll give it a try. Cheers
2018-1-20
Nebicaneser
Phil Mountain Posted at 2018-1-20 12:05
hope it solve the problem
2018-1-20
Tom Saavedra
Flight distance : 38415 ft
I just did a successful test flight after having update problems.
I’m using an iPad Mini 2 though.
One of the few things I tested was Active Track.
Although I haven’t used it in a while, I thought it worked better than ever.
Hope you get it sorted out.
2018-1-20
Phil Mountain
Tom Saavedra Posted at 2018-1-20 12:16
I'm going to try do a firmware 'refresh ' using DJI Assistant 2 on the pc
2018-1-20
Tom Saavedra
Phil Mountain Posted at 2018-1-20 12:23
Sounds weird, but first format the SD card, downgrade, update again, then format SD card again.
2018-1-20
Phil Mountain
I'll give it a go Tom. It can't harm. Thanks
2018-1-20
giorgos1966
Flight distance : 273757 ft
Greece
Hi my friend.What tablet android you have? With new  AC firmware 0300 have you had other problems?
2018-1-20
Phil Mountain
Just a Marshmallow one. No other problems. Going to try on a 7.0 Nougat Samsung galaxy s7
2018-1-20
giorgos1966
Greece
Phil Mountain Posted at 2018-1-20 14:15
Me too now did the update the last firmware AC and last dji go 4 (4.1.22) with tablet (Nvidia Shield k1) Android 6.0 . I will fly to see if it's okay.
2018-1-20
giorgos1966
Greece
This is true after upgrading new firmware ?   << If you have multiple Phantom 4 Pro intelligent batteries, insert each additional battery and perform the preceding steps to upgrade.>>
2018-1-21
