Geebax
I am puzzled about your comment 'before I gotr an SD card to record footage'. Every P3 should come with an SD card fitted from the factory.
But, yes, you have some jello in the images. Jello is caused by the camera vibrating. Being a P3, these aircraft came with a sponge plastic pad jammed in on the back of the gimbal arm to protect it during transmit, you might check that is has been removed. Also, they come with 4 plastic anti-drop pins, but only two must be fitted, not all four. Only fit 2 diagonally opposite each other.
