Mark The Droner
Flight distance : 2917 ft
Boosters can be anything that increases range such as an amplifier or a better antenna. In this case, you're talking about windsurfers, sometimes called reflectors or deflectors and it sometimes includes the word parabolic. It turns an omni antenna into a directional antenna which enables the pilot to send more signal strength in the desired direction. They have to be well designed... IMO they should be supported at both ends of the antenna to maintain the correct and consistent distance from the antenna at both top and bottom and also so that the deflected signal is sent in the intended direction with precision (not too high/low) - relative to the primary non-deflected signal. The surface of the deflector should be uniformly curved and not warped - and the surface should also be smooth. Ideally, the antenna assembly would be aimed by the pilot perfectly - not only in terms of left/right, but also up/down. They won't work with some Phantoms such as the P3SE since the stick antenna doesn't communicate with the AC. They also won't help FPV range with the P3S since the FPV antennas are hidden inside the controller on that system. The P4 controller (and the other three P3 systems) has two visible antennas, both of which communicate with the AC, so they should all work nicely, and there is plenty of evidence of increased range all over the internet in forums and youtube. Erskin's original design circa 2002 works for both 2.4 ghz and 5.8 ghz. And that's convenient since many of the systems these days can switch between those two frequencies. These aren't Erskin's exact design, however, as the deflectors we see today on Amazon and eBay that are made for twin antennas aren't as wide - and also the focal point is not set as deep within the parabola. Still - RC pilots have been using variations of this windsurfer design since at least 2013 and range is improved even if the deflector design isn't quite perfect.
