Spark went in Atti mode, what went wrong
123Next >
6170 81 2018-1-21
DirkGerrit
Flight distance : 276424 ft
After weeks of terrible weather today I could fly with my spark. Two fligths went well. The third flight the spark went into Atti mode after a lot of yaw errors. I was able to land in Atti mode but I am very curious what I did wrong and I want to learn how to avoid this the next time. Spark has the laterst firmware and my Iphone 6s the latest IOS. The weather was good, almost no wind. Any tips?
2018-1-21
DirkGerrit
http://www.phantomhelp.com/LogViewer/S60UOZ8FNHUJNPT68EHY/
2018-1-21
Tviscomi
Flight distance : 106886 ft
Following this thread with interest. The error you have received are very similar to what some others here have experienced and no explanation has been given by DJI.
2018-1-21
A CW
Flight distance : 13838848 ft
Other than taking off with a very low battery temperature I do not believe this to be pilot error. Nothing in the flight record shouts out anything except a malfunction with the drone - especially given that this is your 3rd consecutive flight at the same location with no issues on the first 2 flights. Yep - it would be nice if DJI replied to your post here as I too am interested to see why this happened given that this is not an isolated case.
2018-1-21
Bright Spark
Flight distance : 22129 ft
Batt temp warning at takeoff. Seems odd requiring more than 15 gegrees.
2018-1-21
Tviscomi
A CW Posted at 2018-1-21 06:50
Exactly...the flying environment looks to be ideal.  No buildings, power lines, etc..  The OP was flying at a minimal altitude & distance.
2018-1-21
A CW
Tviscomi Posted at 2018-1-21 06:55
And he even hovered for a while to warm the battery to the required 20c+ and being his third flight in a row the drone would have been warm anyway.
2018-1-21
A CW
How would the speed of the wind at 100' above the home point cause the drone to experience a yaw error before encountering a compass failure and switching to ATTI mode one second later?
2018-1-21
DirkGerrit
2018-1-21
DirkGerrit
DirkGerrit Posted at 2018-1-21 07:12
https://www.youtube.com/watch?v=vu4JdanD4V0&feature=youtu.be
This is the video footage of this flight
2018-1-21
DirkGerrit
A CW Posted at 2018-1-21 07:02
Windspeed was 2 beaufort, temp 7 degrees celsius
2018-1-21
Tviscomi
OP, just for the heck of it try opening a support case with DJI and see what they have to say about the issue(s)
2018-1-21
A CW
DirkGerrit Posted at 2018-1-21 07:15
Exactly - the wind was not the cause of your incident and bears no relevance to the malfunction.
2018-1-21
Bright Spark
Hi , sorry, I saw he said no wind afterwards . apologies to all.
2018-1-21
Bright Spark
Just a few observations. I'm keen to learn how to analyse these problems and welcome corrections.
I feel a batt temp of 15 is not very low and I wouldn't fly if that error appeared at start  up. I must say I think it was  a fresh battery looking at the cell voltage.
2018-1-21
Strobing_NYC_Sp
Flight distance : 3866470 ft
This is the one issue I have seen with the spark, getting YAW errors and going into ATTI mode. Please DJI inform us as to why it would do this with nothing around to interfere with GPS or Wifi
2018-1-21
rimza
Flight distance : 3307 ft
Brunei
csv
csv
between 130 secs to 171 secs, gps health dips to zero but csv records only reflect primarily yaw errors. Also satellite counts are still healthy.
2018-1-21
Bright Spark
Just interested in what is the speed scale on the red track at max. Almost full speed just precedes the gps failure.?
2018-1-21
rimza
Brunei
YAW reference during the flight versus the grey area in ATTI mode.
2018-1-21
rimza
Brunei
Bright Spark Posted at 2018-1-21 08:02
Top speed prior to ATTI mode was at 0.36m/sec
2018-1-21
rimza
Brunei
2018-1-21
Bright Spark
At exactly 146 there is a burst of speed on film.
2018-1-21
JJBspark
Flight distance : 12132231 ft
rimza Posted at 2018-1-21 07:51
[view_image]
HI Rimza, is this figure made with the data from the flightrecord.txt file?if not, from where did you have this data ?
Just very curious because i am working on a analysis program myself.
cheers JJB
2018-1-21
rimza
Brunei
2018-1-21
rimza
Brunei
JJBspark Posted at 2018-1-21 08:22
yes, easier to see in graphical form. Use CsvView.
http://datfile.net/CsvView/intro.html
2018-1-21
JJBspark
rimza Posted at 2018-1-21 08:23
true, but i do not see the YAW ERROR LARGE in there.....
see my chart with the same data
2018-1-21
rimza
Brunei
select nongpscause and the yaw errors pop up The pink area is the duration AC reporting large yaw error.
2018-1-21
stealther
Flight distance : 406486 ft
Did you look at the compass direction before and after the flight? I mean did the symbol on the screen show the AC was pointing correctly?
2018-1-21
Bright Spark
At about 3.56, the ac is dislodged in the grass , motors running?
2018-1-21
Bright Spark
I would work backwards. You have a great big field. Try and reproduce the problem.
Fly upwind  with compass sensor screen selected, close in, and see if compass goes yellow/red with various moves and speeds.
2018-1-21
Bright Spark
Further to my observations, it could , I say could ,be that after a spell of highish speed, if a turn is instigated purely by yaw input, the spark will continue through inertia straight on for a while. The gps tracking will then be at variance with compass and/or gyro input.
2018-1-21
DirkGerrit
stealther Posted at 2018-1-21 11:21
no, the flight before I did but this flight I forgot..
2018-1-21
DirkGerrit
Bright Spark Posted at 2018-1-21 11:27
I stopped the motors when the spark landed in the gras, when I walked to the point the spark landed I didn't,  see the spark so I started the engine again and found it.
2018-1-21
Bright Spark
Thought so!
2018-1-21
DirkGerrit
Tviscomi Posted at 2018-1-21 07:19
Want to do another flight and see if the problem persists before opening a support case
2018-1-21
Enri
Flight distance : 683501 ft
I hope you will contact dji support, because this is a relevant incident and is second in a row. Lucky you, it is the last in a cue and second where the owner managed to recover the aircraft. I would no doubt be glad your contact dji support and see support itself following with an official statement about it. Curiously if you search the forum you will found the same incident. A guy in Belgium (close to you) in an open field like the one you were flying with a river at his west. Same bit of wind (no wind alarm) and went to atti after a steep turn...and gone with the wind for 500ft.
2018-1-21
DJI Elektra
DirkGerrit Posted at 2018-1-21 12:10
Sir, please export the flight data and the black box for analysis. Did you crash your drone before? Thanks for your help.
2018-1-22
DirkGerrit
DJI Elektra Posted at 2018-1-22 02:36
https://www.youtube.com/watch?v=ngEHdAlAh9A
Hello DJI Elektra, the drone didn't crash, it landed safely. I never had a crash with the spark. I will find out how to export the flight data and black box, then I will send it.
2018-1-22
DirkGerrit
DirkGerrit Posted at 2018-1-22 10:40
How and where can I send the log files?
2018-1-22
DirkGerrit
DirkGerrit Posted at 2018-1-22 11:32
Dji elektra, the logfiles are on my harddisk. How do I sent it to you?
2018-1-23
123Next >
