Crystalsky Ultra - backlight failures
123Next >
11219 92 2018-1-21
lannes
Flight distance : 4465 ft
I just wanted to create a thread to bring to the notice of DJI,  the number of increasing blacklight failures on the the Crystalsky Ultra.These have been recorded not only here but on other forums as well.
It seems that the failures are occuring either immediately on start up or about 1 hr into a flight session when the CS heats up.
Some units are overheating very quickly.
I have stopped using the Ultra for fear that the current version of the DJI Go4 app (4.1.18) is the reason for the cpu/gpu overload.
If you have had a failure can you please make a post here and then we can refer it to the engineers via the DJI moderators.
If you could add a date for the failure, we might be able to link it back to a particular upgrade event.
2018-1-21
Forestjim
Flight distance : 6606519 ft
Oh no.... but oh yes.!!!!
Black light gone again for the 2nd time on my CS Ultra today.
Last August I had the BL go in the 5.5.
The CS this time had around I’d say about 5 hours on it.
It felt hot after I landed.
I don’t know if I got a warning about the heating as I was flying home on the sticks. I just was changing the battery and went to fly back out and the BL was toast.
I was at the Gold Coast in Australia at about 11am, the temp was about 30c.
I was flying most of the time with the CS in the shade.
I contacted DJI in Australia the were very sorry and thye are sending me an express post return label.
They said they will change it over very fast.
I asked them about the previous Backlight return in early January. They said they replaced the LCD unit.
That’s sounds correct as the case was my original unit but the screen looked new.
2018-1-21
lannes
Forestjim Posted at 2018-1-21 20:32
Wow Jim, you have had some bad luck with these units, didn't realise you also had a earlier 5.5 failure.
This is the first time I've heard of a 5.5 failing, so it looks like a design issue as opposed to QC or hardware.
2018-1-21
lannes
These are the failure posts I have collected so far
https://mavicpilots.com/threads/crystalsky-screen-blank.21637/
https://forum.dji.com/thread-129829-1-1.html
https://forum.dji.com/thread-128879-1-1.html
https://forum.dji.com/thread-125365-1-1.html
https://forum.dji.com/forum.php? ... 0365&fromuid=920936
https://forum.dji.com/forum.php? ... 1755&fromuid=920936
https://forum.dji.com/forum.php? ... 0121&fromuid=920936
https://mavicpilots.com/threads/ ... /page-6#post-383781
https://forum.dji.com/thread-131936-1-1.html
https://phantompilots.com/thread ... 29366/#post-1321892
https://forum.dji.com/thread-127843-1-1.html
https://phantompilots.com/thread ... ting-issues.129842/
https://mavicpilots.com/threads/ ... heat-warning.32312/
2018-1-21
Tviscomi
Flight distance : 106886 ft
I'm a little upset that I bought my CS in the winter because I am not using all that much and it's just sitting around using up valuable warranty time.
2018-1-22
Forestjim
Tviscomi Posted at 2018-1-22 03:11
I don’t think they like the heat.
Having said that the backlight did fail in my 5.5 in an Aussie winter.
Looks like to me it could be an Ultra thing at the moment.
I usually only turn the brightness up to about 30% in the shade & 50% in the sun.
2018-1-22
Tviscomi
Forestjim Posted at 2018-1-22 03:28
Yes I have the UB.  I ran an indoor test last week with the CS connected to my AC and left it on at high brightness for 30+ minutes at room temp.  I took IR thermo readings and the hottest it got by the HDMI port was 117 F.
2018-1-22
Forestjim
Tviscomi Posted at 2018-1-22 04:05
This is not good
2018-1-23
Tviscomi
I should have also mentioned that mine hasn't had any issues...yet
2018-1-23
sitka_rn
Flight distance : 3107 ft
I ordered an UB in Aug and unit shipped mid-Nov from Adorama.  Had no problems with a few flights P4P and 1 flight with Mavic Pro after using UB for set-up and firmware updates. Put freshly charged battery in this AM ... after 15 mins incredibly hot and screen began to flash/flicker.   Tried to power off with button but no go so pulled battery.  Let sit for 8 hours... re-charged battery 100%. Screen completely black get small vibration with 1st push power button.. no beep  For almost $900... VERY unhappy.. and no one to call during weekend.
2018-2-10
Forestjim
sitka_rn Posted at 2018-2-10 19:58
I’m sorry to say your backlight has fried.
Your problem is the same as I’ve had 3 times.
You say you can hear tones. In the dark get a torch and shine in on the screen.
You should be able to see the home screen.
Make arrangements to return your.CS as it’s toast.
The recent update a couple of days ago, fingers crossed looks promising it has fixed the problem of over hearting.
2018-2-10
fans2ee5f604
Flight distance : 412274 ft
Backlight failure happened to me at my maiden flight with the ultra! I bought it a week ago.  Very disappointing on the QC of Crystalsky, it doesn't look like a product from DJI!!!!!!
2018-2-11
Forestjim
fans2ee5f604 Posted at 2018-2-11 16:53
Yes, not good at all.
All my backlight fails happened during the first battery of the day.
I think there was a bug in DJI Go4 causing the CS to overheat & I don't think the fans were coming on to cool it down.
2018-2-11
fans2ee5f604
Forestjim Posted at 2018-2-11 17:09
I was updating the Crystalsky with the CS turned on. It went completely dark after my Mavic  Pro  took off. I was luck that my Mavic was on my line of sight so I can steer it back and landed safely.
Very disappointing and frustrating., I have a 5.5 CS which I have used for months and gave me no problems.
If Ultra has problems then DJI should not sell it!!!!!!!
2018-2-11
dan_vector
Flight distance : 613753 ft
Oman
Has anyone repeated their tests on the new firmware release to see if temps are more acceptable and the fans are coming on as expected.
I'm hopeful that the back light failures are due to overheating and that if the new firmware better controls internal temperatures then it may prevent back light failures.
I haven't used my UB since all the back light issues started to occur as it is difficult to get repair/warranty services in the country I am based in.
2018-2-11
YOYOMAN
Flight distance : 676260 ft
Réunion
dan_vector Posted at 2018-2-11 21:38
I flew 2hours in direct sun yesterday with my P4P & CS ULTRA.
And the monitor was very Fluid, no App crash, and no Overheating (for information, before firmware upgrade, I get overheating issue after only 18min flight)
So yes, I can say I'm happy
2018-2-11
dan_vector
Oman
YOYOMAN Posted at 2018-2-11 21:49
Good news!! I updated my unit last night so I'll chance it later. We shall see! Thanks for the feedback
2018-2-12
lannes
dan_vector Posted at 2018-2-12 00:11
I've tested the Crystalsky Ultra with DJI Go 4.2.4 for 1.5 hours continously on full brightness and with the latest firmware for the AC, 3 full flights with the MPP and MA, ambient temp 23c and there wasn't a single glitch in the monitor, this was 4k 24fps, with caching back to the CS at 7gb
The hottest the Ultra panel got on max brightness was 41.5c , the side ports got to 38.6c and the back panel near the ports to 40c.
The CS fan never came on at all during the 1.5hrs and the temp was pretty consistent from about 15min from start up to the end. I'm not sure what the normal operating temperatures are for the CS Ultra, so the fan not comming on might be an issue, funny thing to note was the RC fan was humming away after 30mins and that has never come on before in longer flight sessions
DJI Go 4 4.2.4 worked flawlessly, there was no latency or pixelation at anytime in RC signal out or HD signal back, mind you I was using a Titan Cyclone 2.4ghz amplified panel.
I think they may have fixed the overheating problem for now, my CS build date it the 15/10/17 for reference, a couple of us who have this build date have CS Ultra's that get hot but have never failed.
Interesting to see how the other CS Ultra owners are fairing with the need firmware and 4.2.4
2018-2-12
Pauxier
Flight distance : 1213238 ft
Still waiting on weather here
2018-2-12
Kune
Flight distance : 2773465 ft
To be honest I was about to buy the crystalsky but reading all the negative comments I am unsure about it.....
Could you please tell me if you were me, ....  should I buy it? I was thinking on the small one 5.5".    Is this size having issues as well?
Which one is having the issues? All of them? or only the Ulta (the most expensive one) ot the high Brightness 7.85" or 5.5"?
2018-2-12
sitka_rn
Forestjim Posted at 2018-2-10 20:39
With a very bright light sitting flat against screen... I get a small DJI flash sceen then hits Main screen and shuts down with 3 beeps on own.. have asked for warranty help from DJI.. unit < 90 days old
2018-2-12
Forestjim
sitka_rn Posted at 2018-2-12 10:34
Ok... your test has confirmed Backlight fail.
Good luck.. I hope you are back in the sky soon.
2018-2-12
fansee00f5cc
Flight distance : 221414 ft
Bought my ultra Nov last year, worked on full brightness until yesterday. Went black, backlight failed, fortunately it was at the end of a long flight and overhead. Quick response from DJI, hope they can fix it for good.
2018-3-6
lannes
fansee00f5cc Posted at 2018-3-6 12:39
Disappoining, unfortunately that is the problem with the Ultra they can work perfectly for a long time and then fail at anytime.
I think the 2000 nits is too far a stretch until they have solved the heating problem, how long were you using it on full brightness for ?
Unfortunately I think it's only a matter of time before they all fail
2018-3-6
sitka_rn
My crystal ultra arrived at DJI California Feb 26th...  Today is Mar 7th... no word from DJI support... no response as to whether I will get a new device or repair. I do not want someone else's refurbished product for a device less than 90 days old... What have others experienced in terms of turn around time and replacement new vs replacement refurbished?
2018-3-7
castormalin
Flight distance : 638911 ft
On my first CS, the compass was not working, the device was crashing in flight after few seconds, the FPS rate was very low with DJIGo
I got as replacement a refurbished one: the compass is not working, it doesn't crash in flight, the FPS rate is the same as the first one
2018-3-7
fansee00f5cc
Although I was disappointed that the Ultra bright 7.8" crystal sky backlight failed in the middle of a flight after only3 months use I was pleased with just how quickly DJI responded to my emails and sent me a return post paid mailing label to return the unit to DJI Australia. Fingers crossed for a quick repair/replacement. I guess I will go back to the Airpad 2 for a while.
2018-3-8
YOYOMAN
Réunion
lannes Posted at 2018-3-6 13:03
Hi guys,
Could you check if Overexposure Warning (in camera setting) works well with your ULTRA Crystalsky please?
https://forum.dji.com/forum.php? ... p;extra=#pid1242317
2018-3-8
lannes
YOYOMAN Posted at 2018-3-8 04:12
Hi guys,
2018-3-8
PilotSmith
Flight distance : 706539 ft
i just got one today and BANG  within 5 mins it stopped working
2018-4-4
lannes
PilotSmith Posted at 2018-4-4 18:42
That's bad luck, was there any contributing circumstances or did you just turn it on and it failed ?
2018-4-5
Samahita
Flight distance : 17041 ft
Sri Lanka
My CS UB worked 4 minutes... Got hot and Black.
Fan did 1st turn on after screen died.
How do one get these replaced or refunded?
Paid 1300$ and it worked (kind of) ONLY 1 single time....
2018-4-15
lannes
Samahita Posted at 2018-4-15 23:31
Where did you get your CS UB from, probably reach out to your seller if you want a refund and DJI if you want a repair
2018-4-16
*rbh-andy*
Flight distance : 7489642 ft
Three Days ago my Ultra Backlight blacked out also. We where flying in sunny weather around 18c, there were now sun rays shining on the display.
My CamOp got a hot temperature warning, shortly before the black out. There was no opportunity to land. In total the Crystalsky wasn‘t hot!
Now I have to handle with DJI Service Center in China, because I brought the display there, dam!
2018-5-2
Forestjim
*rbh-andy* Posted at 2018-5-2 14:32
Unfortunately, welcome to the club.
Can you tell me what version of firmware you were using?
I'm trying to work out why these things are still failing.
The last update was 12th April
2018-5-2
barry1
Flight distance : 193947 ft
I just used my month old Crystal Sky Ultra and the backlight failed on me today. Right in the middle of my flight.
2018-5-2
HedgeTrimmer
Forestjim Posted at 2018-5-2 16:12
The following might be of interst to you.
How to turn on Debugging on CrystalSky.
https://forum.dji.com/forum.php?mod=redirect&goto=findpost&ptid=143740&pid=1332183&fromuid=1516520
Along with information on firmware being run on my CS-Ub.
https://forum.dji.com/forum.php? ... 301&fromuid=1516520
2018-5-2
Coyut
Flight distance : 2559222 ft
Switzerland
Update:
The screens are back in the dji store today.
The larger screen units are not available in the store anymore world wide.
Not out of stock, they are completely gone.
So my guess is they will sell a complete new unit in the future . The question is what will happen with our remaining units that might fail soon.
2018-5-3
Forestjim
Coyut Posted at 2018-5-3 00:35
Update:
That’s strange. The Ultra are showing in stock on their website
https://m.dji.com/product/crystalsky
2018-5-3
Coyut
Switzerland
As written as a update in my last post
2018-5-3
123Next >
