Antonio76
Flight distance : 144403 ft
Denmark
mm737cap Posted at 2018-1-22 11:02
Sorry, I did a lousy job of explaining. I'm using the supplied charger for the P4P battery. Just trying to charge it via an inverter I have, and also with the AC power plug in the Jeep itself. Neither will provide enough juice to charge the P4P battery with it's charger. The Mavic battery must need less power because it charges (with it's respective charger) just fine.
OK, then probably the inverter does not provide enough power. If it is rated at 150 W then probably it gives out something less than that, so one with a higher rating might do -but there would still be a question mark re sine wave vs pulsed output... I think the car battery should be enough to drive the car charger, so that is what I would recommend.., A Jeep is not one of the pocket-sized cars you normally see on european roads (personally none of my cars has had less than 90 Amps battery, but they were diesels, which normally have stronger batteries) |
