How to turn off auto landing?
9902 12 2018-1-21
Ray_Dunakin
I've read here that many people recommend turning off auto landing when flying low over water, to prevent the Mavic from accidentally descending into the water. But I'm having trouble finding where this setting is in the app.
2018-1-21
Lukas_Scowen
New Zealand
This doesn't answer your question, as I'm only semi-new to the whole drone world myself. But I'd also recommend turning off your bottom senses when flying over water. It's something a few of my drone friends have done in the past and has saved their bank a bit of a bash..
Good luck!
2018-1-21
Jenee 2
Flight distance : 7852129 ft
This should help:
https://store.dji.com/guides/dji-go-4-manual/4/
2018-1-21
nottuppaware
Flight distance : 70745 ft
Its not auto land they are turning off but the downward facing sensors.
Water and shinny surfaces cause them to judge distance incorrectly so if you were a couple of meters above the water it might think its much closer and try to auto land into the water.
From the side menu its listed under Visual Navigation Settings > Enable vision positioning  ( I think )
2018-1-21
Woe
Flight distance : 4129268 ft
Lukas_Scowen Posted at 2018-1-21 19:56
Good luck!
Those were the good old days. You don’t need to turn off anything. I fly over water regularly and don’t turn anything off. Just stay a safe distance above the water.
2018-1-21
Woe
That feature is not on the Mavic. Because you don’t need to do any of that. Phantom series yes.
2018-1-21
Lukas_Scowen
New Zealand
Woe Posted at 2018-1-21 20:40
Really? each time I fly over water I get sensor warning. I'll show ya next time, maybe a problem?
2018-1-22
Jyunte
Flight distance : 2103150 ft
Here's a video from Ed Ricker, where he puts "Turning off the Downward Vinson Sensors while Flying Over Water" theory to the test.
2018-1-22
Tango_B
Flight distance : 2891473 ft
To do this - disable "Landing Protection". Be careful though, when you want to bring it in to land, descend very very s l o w l y .
2018-1-22
Simmo1
Flight distance : 1624 ft
Tango_B Posted at 2018-1-22 23:06
I'm sorry, why would this help in this situation?
2018-1-22
DroneFlying
Flight distance : 10774613 ft
Simmo1 Posted at 2018-1-22 23:29
Disabling Landing Protection is the correct answer, and disabling it helps because it'll prevent the Mavic from landing in the water when the pilot pulls back on the throttle while VPS / bottom sensor indicates that the Mavic is near the ground. As long as Landing Protection is disabled, negative throttle will only reduce the Mavic's height, but when it's enabled negative throttle can cause the Mavic to go into landing mode and continue descending without further stick input.
2018-1-23
Tango_B
"Disabling Landing Protection is the correct answer, and disabling it helps because it'll prevent the Mavic from landing in the water when the pilot pulls back on the throttle while VPS / bottom sensor indicates that the Mavic is near the ground. As long as Landing Protection is disabled, negative throttle will only reduce the Mavic's height, but when it's enabled negative throttle can cause the Mavic to go into landing mode and continue descending without further stick input."
This.
2018-1-23
djiuser_n9uHhc0eeyLA
Austria
Where can I disable landing 'protection' for Mini2?
My drone tried to make sucide in Cetina river one week after I bought it. That unexpected descend shocked me so much that it already touched the water after I started to pull it up. Luckily no damage remained. It might have been a different story in sea water.
I struggle a lot with the menu of the dji app because some features are only adjustable in certain circumstances.
I wouldn't be surprised that I didn't find how to turn off landing protection because I was not in flight mode xyz or missed something else.
This is one of the reason why I didn't do a seaside shot at the Kalithea springs today. A pity.
Chilli
2022-8-9
