dj_dread
Flight distance : 648399 ft
Romania
after palm launch, you need to stand in front of the drone 0.5-0.7m away. raise your hand, palm in front. if the front leds are green then it "sees" your hand. if they are yellow then you need to go near the drone or back away from the drone. one the leds are green, then SLOWLY move your palm. if you want to take a selfie, you need to "wave" your hand, the drone will fly backwards and up a bit and that's the "follow" mode. only then you can take a selfie.
it is working in my case. it really depends what you are wearing. if i am all "black" i need to insist couple of times until everything works. another thing i noticed is, if the Spark is heading sunlight, it may not correctly recognize the gestures. |
