Dji osmo X3 No video Feed on Phone.
1298 7 2018-1-21
fans83ad0550
Kenya
No video feed on my phone but when you press record it will record but can't view the files since they are corrupted unless I view them on my PC..secondly my osmo has a non stop beeping sound after starting it and the green light blink in sync with the beeping..kindly help..
2018-1-21
Hi there, just to clarify, are you sure the three of gimbal axis have been unlocked before you power on?
Do you also install DJI Go 4 in your mobile phone? If yes, please make sure it has been closed completely when you run DJI Go.
Besides, what mobile device are you using? Have you tried another one? Thank you.
2018-1-21
fans83ad0550
Kenya
Thankyou for your reply...before I start my dji osmo I unlock all the axis...haven't installed DJI Go 4..I have been using Samsung grand neo...And how do i go about the beeping sound and green light blinking..
2018-1-22
fans83ad0550 Posted at 2018-1-22 12:17
Any chance to post a short video about the issue in YouTube and share us the link? We will help to verify if we can get it sorted out remotely, thank you.
2018-1-23
fans83ad0550
Kenya
Hi I have also noted that my battery level is 100% constant even when it is about to die also the videos that I record are corrupted.before I used to have copies of the pictures on my phone and the sd card.tried removing my sd card but still the black screen is there n before even with no sd card i could a live feed..kindly assist i feel messed up..managed to upload a vihttps as you requested..
https://youth.be/rXZZmn9LNA
2018-1-26
fans83ad0550
Kenya
Did what you he'd asked me and still no feed back from you guys...is there still hope of using this camera again?
2018-1-31
djiuser_a4DtQpKuowUT
Philippines
i have same problem.. all functioning except no live view of the camera. pls help dji team. thanks.
2018-2-24
Philippines
Anyone from DJI can fix this problem... no video feed.
2018-3-5
