Chris_A
Flight distance : 6142 ft
Did you upgrade the aircraft using the SD card? If so, switch off the aircraft. remove the SD card (format it) and re-insert into the aircraft, then power on - the aircraft should boot normally. The beeps indicate that the firmware has been applied correctly (BB-BB-BB-) also indicated by the green status LED on the camera.
/Chris |
