fans2108d20a
Flight distance : 178002 ft
Malaysia
szyrek Posted at 5-25 06:57
I had the same kind of issue (lost linking, no possibility to reset anything, no beeps when holding power button, lost connection with dji assistant). I actually did resolve it in my case by removing the SD card which turned out to be fault. Seems like spark is trying to read/mount/format and when it fails doing that it goes into some unexpected state in which it doesn't put out wifi signal so you cant connect and also doesn't react to any "reset" functions, be it resetting link to RC, resetting wifi, etc. Anyhow- if you have simmilar problem make sure you also try to remove sd card- it seems like if its faulty it might actually give you this kind of sympthoms.
Hi, yes its works for me, was same problem with connection, lost wifi and power button not responding for long press, i removed SD card and all works. Thanks |
